Help my use Mr dyno.
Well one of my friends has a Mr. dyno and i am having problems setting it up. I know how to get around the menu, but i am having problems changing settings that are already there. For example changing the tempurture settings i can get to it, but i don't know how to change the settings. I know a couple of you have set them up for the SVX and are wondering if you would know. Thanks
I always need to have the manual for it when I use it. Do you have the manual handy?
I do, i get every thing how to navigate, how to use functions, but it does not say how to change a value in it, thats the only problem i have.
Once you have the value that you want, you press the "down-left" arrow key. You can press it one more time to review the value you entered. Press it yet again to get back to the menu.
I know how to accept a value, i just don't know how to change a value. For exapamle i dont know how to cahnge the tempurture settings from 50 deggres to 60 deggres.
I assume you found the "DegF" sign on the Mr. Dyno display. Then press the "return" button once. The current temperature will appear. Press the "up/down" arrows to adjust the temperature. Then press return after you reach the temperature that you want.
Thread Tools | |
Display Modes | |
