Old 04-14-2005, 09:00 AM
svx_commuter's Avatar
Idle roller bearings for the T-belt.
Well it’s getting to be that time of the year ago to change my timing belt. I’m only kidding, it’s been about 3 years since I changed it last.
I am concerned about all the idle rollers for the T-belt. They have about 237,000 miles on them and I think they may need replacement. Unless somone knows they will make it to 300,000. I do not want to go back in and replace them if one goes bad.
I know Beav has drilled holes in the seals and put oil in his. How’s that working? I think mine sounded a little dry the last time I had them out.
Has anybody tried to press out the old bearing and install new bearings in the idle rollers? I would like to do this.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 04-14-2005, 09:23 AM
dcarrb dcarrb is offline
Yes, there was a thread concerning this fairly recently; you ought to be able to track it down with a search.
Given the cost of the replacement bearings and the hassle factor invloved, I figured from what I read that I'd just as soon buy new idlers, but you may conclude differently.
dcb
Old 04-14-2005, 10:12 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Just to speed the search up for you:
http://www.subaruparts.com/diag/?mod...ategory=013A-1
At $160 for both.... Figuring $20 to $25 an hour for your time at rebuilding them...Another $30 for the Curse jar, and $2 in bandaids......
Yeah.. It may be better to buy them.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 04-14-2005, 11:06 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I just got around to replacing my cam and crank seals Saturday. I had drilled and lubricated the idlers and tensioner with wheel bearing grease, what, a year or two ago? All is still good, although the hot glue I used to seal the holes didn't last. This time I just put a dab of RTV over the holes, I'll check them in a year or so and see how they are doing.
A 1/16th inch hole in the seal, grease with wheel bearing grease using a pocket fitting adapter (see:http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=) and close with a dab of RTV, after cleaning the area around the hole.
Personally, I'd choke if I had to spend ca. $100/ea for five idlers. I'm having a hard enough time swallowing $300 for a pair of engine mounts and another $660 for Konis. I haven't yet and I'm still in the hunt if anyone has any suggestions.
Old 04-15-2005, 06:06 AM
Would you install used engine mounts?
Old 04-15-2005, 08:16 AM
I'd have to look at the idlers for the SVX, but I know for sure on the ones for an XT6, you can press out the bearing and press in a new one, it uses a standard bearing, cost about $5 per idler.....
Old 04-15-2005, 09:48 AM
Beav's Avatar
Not as old as Randy
Make me an offer I can't refuse, John. (in my best Larry with 3 eyes voice)
