Old 08-11-2005, 09:20 PM
1992SVX 1992SVX is offline
do i have too call them beacuse i can not find them online from there website
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 08-11-2005, 10:08 PM
914helo 914helo is offline
I sent them an email asking about their svx kit. Like the previous posts, it is a 1/4" thick for the intake manifold and throttle body, and comes with new bolts. It's also reasonably priced. I figured since my intake manifold was off, this would be a good time to add them on.
Kent
Old 08-12-2005, 02:24 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Originally Posted by Chiketkd
Interesting. I wonder in which model year was the a/c plumbing changed on the SVX?
-Chike
Probably when they changed the gas from R12 to R134.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-12-2005, 04:21 AM
The Molinator
PHENOLIC Spacers
So.....this mod requires two (2) sets of upper intake manifold gaskets, RIGHT?
Please explain Throttle Body bypass (in kit)...?
THANKS!
P.S. I'm in the middle of a head gasket job....and I want to do any reasonable service, upgrade, or mod that can be done more cheaply because engine will be out....and somewhat apart! THANKS!
Jim
Old 08-12-2005, 07:31 AM
The throttle bypass is a metal tube used to join two "coolant hoses" that usually connect to the throttle body, not to cool, but to heat the throttle body, so that it does not ICE UP at high velocity, or high altitude, or in very cold weather.
The phenolic spacers, and coolant bypass are designed to lower the intake manifold temperature, for a more dense, oxygen filled, powerful, air charge into the engine.
Old 08-12-2005, 03:07 PM
MaxImUmZ MaxImUmZ is offline
On a SVX board with a Z31 name
Send a message via AIM to MaxImUmZ Send a message via Yahoo to MaxImUmZ
Difficulty of install?? 3-4 hours is that your average weekend mechanic or someone who really knows what they are doing?
1995 Red LSi
Mods: ECUTune Stage One, Smallcar shift kit, removed side SVX badges(weight reduction )
Future plans: Alcyone emblem, black out taillights (Not that I think it looks overly good I just like people having no idea what it is and want to add to the confusion)
Old 08-12-2005, 03:32 PM
When I did my first one I wrote this;(post #53)
Old 08-17-2005, 02:25 PM
Just got my spacer kit in from Outlaw engineering. It was very well packaged and shipped to me pretty quickly. They look a little different than the earlier pic's. It appears that they now have gaskets built in to them. I will try to install them tonight and let you know. Here's a couple of pic's.
Kent
Old 08-17-2005, 03:14 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Nope, you still need the Subaru gaskets on either side of them. What you're seeing is just the way Outlaw "seals" the phenolic (that, or they've found a different type of phenolic material to use).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-18-2005, 01:23 PM
Gaskets Now Included!
I spoke to Sean at Outlaw Engineering today, and the phenolic spacers for our SVX engines now come with gaskets in place,(aramid fiber gasket bonded to surface) making it cheaper and easier than before!
You don't have to buy anything else to do this now, and they are much easier to install.
Cool, Thanks Sean!
Old 08-18-2005, 02:55 PM
SVXRide's Avatar
Cool, Thanks Sean!
Tom,
Thanks for checking! I was obviously WRONG in my previous comment. Hope the aramid fiber gasket works out correctly - it will obviously make installation a lot easier.
-Bill
Old 08-18-2005, 07:49 PM
The Molinator
BEAT ME ...to it!
I just found out the same from Sean! I am installing this mod during my head gasket job (just found out it was a head gasket ONLY....NO CRACKED HEAD OR BLOCK!....YAAAAAH!).
Thanks!
Jim
Old 08-18-2005, 08:41 PM
SVXRide's Avatar
Thanks!
Jim,
Good news! Make sure they check the "flatness" of the head before they put everything back together. There is a Subaru spec for the "flatness" in the shop manual.
-Bill
