Old 04-10-2005, 07:24 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Exclamation tranny help needed
my trans. is throwing a code for the line pressure solenoid and when i put the shifter in 3rd it's like neutral until i hit the gas then it goes like normal. also, when it gets down to idle with the shifter in 3rd and in motion it starts bumping into 3rd gear repeatedly like it's trying to engage and can't. how hard is the line press. solenoid to fix? other than 3rd gear though the tranny seems to work just fine.theres no prob for as long as i leave it in 4th.HELP!
Old 04-10-2005, 09:08 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
The line pressure is controled by Duty Solenoid "A". It is located on the top of the valve body. I.E. to replace it you must remove the valve body.
I can give you a manual that explains what it does but the file is to big for an atachment. PM me you e-mail and I will sent it to you.
Also try disconecting the dropping resistor behind the battery. It help regulate line pressure. With it unpluged it should shift harder, I think.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 04-10-2005, 09:47 PM
Budfreak's Avatar
Banned
i tried unplugging the resistor and that was no help. it wouldn't be because the line press. solenoid is dead so it won't matter cause it's stuck at min. press.
Old 04-11-2005, 06:04 PM
If the A solenoid is dead, it should have maximum pressure, hard changes. The 3rd gear thing, seems like the overrun clutch is not engaging, no engine braking. Usually a throttle sensor, setting thing. Strange.
Old 04-11-2005, 06:12 PM
Budfreak's Avatar
Banned
Red face
i've set the throttle position sensor at .500 volts on the dot. the tranny will sometimes overrun a little between 2nd and 3rd when i'm being very very light on the throttle but when i'm on it it seems to do just fine. works great under full throttle. good shifts and all. it seems to like to shift earlier than i like alot though when i don't have my foot in it. i don't know. HELP!
Old 04-12-2005, 04:05 PM
Measure the resistance of the resistor behind the battery. It should be no more than 20 ohms.
Old 04-12-2005, 04:29 PM
Budfreak's Avatar
Banned
i don't have the resistor hooked up.
Old 04-13-2005, 12:24 PM
With it unhooked you will get transmission error 11 and the symptoms you see while in 3rd. If hooking it up doesn't help then the resistor is no good...hence measure the resistance
Old 04-16-2005, 05:11 AM
Budfreak's Avatar
Banned
Talking
are you seriously telling me that the stupid little resistor is the cause of all this??? SWEET!!! i hope that's all it is. i'll check it today. thanx
Old 04-18-2005, 01:18 PM
So what did you find?
Old 04-18-2005, 01:29 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
This might be the guy on the Yahoo site asking for a resistor the other day.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 04-18-2005, 08:09 PM
Budfreak's Avatar
Banned
yes it was me asking for a resistor the other day. found the one on subaruparts butwould prefer not to pay 55 dollars for it. anyone got one cheaper???
Old 04-18-2005, 11:55 PM
Sure... I have one. I can let it go reasonably.
But are you sure it's bad? The actual value of the resistor is 12 ohms. The tolerance is 9 to 15 ohms. Eyeballing it, it looks to be 30Watt. (Wow.. side thought.. Just how much current is this thing pulling?? Over 2amps on the high side?? It's a dropping resistor, so that's just wasted current. )
Anyway... The resistance is low enough, so if you don't have a meter, you can use a flashlight bulb and battery. If the light comes on at all it's good, cause they never short, or waver from tolerance much....They always open.
Robert
Old 04-19-2005, 01:50 AM
Budfreak's Avatar
Banned
Wink
i checked it with my ohm meter and it read infinite. (you test between the two wires on the resistor, right?) so i'm assuming it's bad. how much could i get one of yours for including shipping to akron,oh.?
Old 04-19-2005, 01:55 AM
Isn't it like 4 in the morning in Ohio? You are as bad as I am.
How's bout.... uh... say... $20.00 shipped?
Robert
