Old 04-02-2005, 01:36 AM
customsvx
i want to know about the tranny cooler
i want to know where the stock tranny cooler is and how do i go about replacing it. im pretty much a beginner when it comes to replacing it so i need all of the help i can get and also pics if you have them will help me alot.
Old 04-02-2005, 02:10 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
The stock tranny cooler is built into the bottom of the stock radiator. It's a two pass.
If you remove the splash shield on the bottom front, you can see the hoses connected to the bottom of the radiator. Hopefully one of the hoses is exiting a filter before it reaches the radiator.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 04-02-2005, 02:12 AM
Oh!! The installation of an aftermarket tranny cooler. Do a search for transmission cooler, or tranny cooler. It's been discussed before, with some really outstanding information.
Robert
Old 04-02-2005, 05:26 AM
It is generally accepted that you don't "replace" the stock cooler.
Most people just add an extra one, either in series or in parallel. The reason you don't replace it, it is an expensive liquid/liquid type, which has the great advantage of heating up your tranny oil quickly on cold days/climates to the correct operating temperature.
The reason people add an additional one, hot weather, hard driving, heavy traffic, can create more heat in the tranny than the OEM one is able to do away with.
Do a search and read all the stuff about it is good advice.
Old 04-02-2005, 07:52 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
This is a good thread to start with:
http://www.subaru-svx.net/forum/showthread.php?t=24443
-Chike
2006 Steel Gray WRX TR (sold)
