Old 03-30-2005, 05:25 PM
Berlin
Grinding from the Tranny
I have had a grinding noise for my tranny and yes its the tranny put it up on the lift and hit the gas it made this grinding noise. Anyone else had this problem. Do I need a whole new tranny or what? If I do I would like to attempt the 5 speed swap. It is only when I hit the gas and only in drive gears. Axles are new all fluid is new and full.
Old 03-30-2005, 05:34 PM
Need more info. Does it make the noise in all the forward gears? Does it change when you go on and off the throttle? Did it start all of a sudden, or has it been getting worse over time?
Old 03-30-2005, 05:43 PM
Berlin
Only when I hit the gas no gas no noise. Its been about the same for 4 months now dont notice it in reverse.
Old 03-31-2005, 03:48 PM
Can't be sure, could be the front diff. You could drain the front diff to see if there are any chips of metal there. I would get somebody to listern to it, before it gets worse.
Old 04-04-2005, 11:15 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
that would be my guess too, the front diff
and if thats the case, Id say you are on borrowed
time. If you do tight U turns in a parking lot
and it sounds worse, thats not good either.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 04-06-2005, 06:02 PM
Berlin
Thanks guys for the replys. I will drain the front diff this weekend and see if there is any metal in it.
Old 04-06-2005, 09:53 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
As everyone else says, the description sounds just like when my front diff went bad...horrible grinding sound, but goes away when accelerating, comes back when you let off the gas. If this turns out to be the problem, its not really that expensive a part...all things being relative, since I picked up a pristine used diff for $80 shipped!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
