Old 03-08-2005, 10:23 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Originally Posted by blacknite
Electrophil, Where In Vegas Do You Live??? I Didn't Think There Is Another Member Here, Most People Are In Denver That Is Cool!!!!!!
East side, not far from the Green Valley area. Been here 10 years, and love it. Are you out there on the West side with all those rich folks?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-08-2005, 10:27 PM
Weasel 22
Im almost sold on the ps lines..the leak as I look at it tonight on the ground, is directly under the lines..and the system makes some strange sounds when I turn the wheels..cant really explain the sounds but its not like any car ive owned before..and it doesnt feel right in the assist effort..Ill head in this direction first..thanks for the help
Old 03-08-2005, 10:28 PM
And $300. Is A Lot For A Ps Replacement The Good Thing Is That They Clean Up Your System!!!!
That's what I told em!! I walked around with an attitude for 3 weeks after that. Why? Because 5 months prior they had replaced the P/S pump at some outrageous amount. Why didn't they see a problem then? It was also the last time they saw the 94. I have the 92 there now though to replace the speedo gear. Dropped it off Monday, called them this morning, and twice this afternoon. Did they return my calls?? Nooooooo.... Can't have that, can we?
Robert
Old 03-08-2005, 10:31 PM
Please! Keep the P/S pump topped off with ATF. They burn up in no time. I found that lesson out the hard way.
Robert
Old 03-09-2005, 10:53 AM
blacknite blacknite is offline
I HAD THE SAME PROBLEMS WITH SUBARU DEALER IN HENDERSON.... SND THE WORSE THING IS THAT IT IS THE ONLY ONE AROUND. THEY SUCK!!!!!!!!
WHEN I ARRIVE FROM DENVER MY REAR CV JOINT BROKE, I BARELY MADE IT TO A GAS STATION OFF OF CHARLESTON AND I-15. WE PULL THE CAR TO MY FRIEND APARTMENT AT MOJAVE AND CHARLESTON. AND COULDN'T MOVE THE CAR FOR A COUPLE OF MONTHS, BEEN BROKE NOT KNOWING MY WAY AROUND, NOT BEEN USE TO THE BAD COSTUMER SERVICE. I ALMOST GIVE UP AND WENT BACK, I STILL DON'T KNOW ANYBODY HERE. JUST A COUPLE OF PEOPLE THAT I KNOW FROM COLORADO. MY LIFE IS WORK, FIXED THE SVX AND WORK!!!!! I LIVE BY ALTA AND BUFFALO. WE SHOULD GET I TOUCH LET ME KNOW I HAVE E LOT OF EXPERIENCE ON THE CAR!!!!!! JUST PUT ANOTHER 5 SPEED ON IT IN 12 HOURS EVEN KNOW I WENT OVER TO PULL ONE OFF THE JUNK YARD.....
Old 03-09-2005, 10:55 AM
Weasel Just And Advice Try To Get The 98 Outback Trany Ahead!!!!!!! Just In Case!!!!!!!!!!
Old 03-09-2005, 12:08 PM
I'm willing to bet it's the PS hose(s)
One way to test is to wrap a towel around the hose and drive for a bit. If the oil is on the inside it's the hose.
I've has to replace the high pressure line and noticed the low pressure line was ready to fall off.
Old 03-09-2005, 02:51 PM
waht are the most commont problems with the svx besides trany and bearings????
Old 03-09-2005, 03:47 PM
Brakes warping, visors shorting, wallet emptying
...complete happiness regardless of any/all issues (not that that's a problem )
Old 03-09-2005, 05:03 PM
That wallet emptying part. Been happening alot lately. Speedo gear replacement - $1,050. But! They replaced BOTH plastic gears and only messed up my exhaust system in the process!!
Robert
Old 03-09-2005, 05:32 PM
Sections 1 through 6 of the SVX service manuals
Robert
Old 03-09-2005, 05:52 PM
Wecome To The Svx World!!! Since I Installed The 5 Speed My Life Became A Nightmare And My Girlfriend Is Jelous, I Spend More Time And Money On The Svx Than With Her!!!!
Old 03-09-2005, 05:55 PM
Plus We Can Really Spect Mutch From A Car That Is Unique, More Than 10 Years Old, And That Really Does Not Have Anything In Common With Other Cars, When It Works Fine, It Does Not Compare With No Other!!!!!
Old 03-09-2005, 05:58 PM
Weasel 22
im simply miffed about how many SVXi there are here in Sparks/Reno alone..I know of at least 6 so far..I will track them down one at a time and invite them to join the Subaru club we have here
and thanks big time for the info guys..much appreciated
Old 03-11-2005, 02:39 PM
Weasel 22
alright..the ps passed the towel test..however the towel got oil on its outside..as I checked around it appears I have an engine oil leak behind the block near the drivers side..it drips down and hits the ps lines and the drivers side exhaust..I also didnt top off the oil for the last week and a half, and I have a definate level loss..little over a quart..this explains why hard driving on the freeway creates the situation..pushing the engine exploits the leak..I will soon make an appt at Subaru Specialist in Sacramento..looks like I will have the seals done and timing belt , along with a tranny cooler
