I really dont want to drop the SVX that much, i drive down to many gravel roads, and to many steep driveways. Plus i dont want to get the front cpontrol arms past perpandicular to the car, so the roll center dosent go to low, and it stays in a decent camber curve.
way around, our Prokit. Lowering the center of gravity only can stable the car anyway, and we've never had a camber problem on any car who has our springs. Even if you did need some adjustment adjustable camber bolts are available. Just making a car "stiff" doesnt necessarily make it handle better. A suspension has to move enough to actually work. What tires do you plan on running on ?
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
not to get slightly off topic - but my SVX is practically slammed in the back and the front is just ugly looking. Can I just install lowering springs for the front and leave the rear in it's stock condition?
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
-Bill
Our springs are built like OE and are Progressive wound...
This is the best design for comfort and handling. from what I understand, the coilsovers are linear rate. Linear is generally stiffer from beginning to end. Unless Im wrong about coilovers being Linear
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." Last edited by Motorsport-SVX; 03-07-2005 at 01:57 PM. |
Just want to clarify that the OEM springs are linear rate. I've measured them myself. Coilover springs can come in either progressive or linear rate. It just depends on what people want.
Prototype rear spring near full compression Measured rate of OEM SVX front and rear springs through a full range of travel. Straight line indicates a linear spring rate.
You ROCK Mychailo!
Load testers and graphs...WOO HOO!!
Todd
Down to none |
This is a good thred keep it comin, first good new thred in a long time.
www.svxtasy.com |
But you know what? what I want is one hole unit, no cutting, no drilling, no spring compressors, just one unit that I can bolt in. that is why I am more interested in coilovers. Any ideas?
www.svxtasy.com |
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
#28
I agree with you about lowering the center of graviety (for less weight transfer), but you want to keep the roll centers fariley close to the center of graviety, or else you would need stiffer springs to keep the car to the same amount of roll, when compared to a car with the roll center and center of graviety at the same height. And when you lower alot of cars subaru expecialey, since we have front struts with less than great geometry, there is alot of movement of the roll cneter on the front suspension when you lower the car past whent the point of having the control arms perpandicular to the car. Plus once you past that point, up or down really any suspension movment wont keep your tire in contact with the road as much as it would if the arms were perpandiclular, which reduces traction. |
#29
#30
