New gears and exhaust...Killer!!
Well i finally finished like 20 projects and got around to my svx. I replaced the wheel bearings up front and well...decided that maybe the gears are worn out...lol...and maybe i should replace those too! So i decided to replace them with 4.11's. Well since i had to take the exhaust out to take the diff out i also decided to replace the exhaust from the headers back. They looked like maybe in the next 10 years that i could have an exhaust leak.....so why wait replace it now. Man let me tell you how heavy that freakin tranny was doing this by myself! Can't imagine doing a awd one.
Well everything is together and i lost the diff. plug so i can't fill it with liquid until monday and get a new plug. The exhaust looks and sounds so sweet i couldn't help but redlline it like 20 times. We eliminated all three cats, made two duals into one highflow magnaflow cat, single three inch magnaflow race muffler along with a second straight through race muffler(through the area made for the rear awd) and split again for two dulas with dual square tips on each side. It looks too sweet and sounds like Ferrari f40!!! I actually had a couple guys come from the garage next door to find out what it was, they tought it was a turbo porsche or something along that lines. (and they work on turbo cars.) We are going to start putting together kits for 2wd and also awd svx's and installing them. I'll post pics tommorrow night. Can't wait to drive it monday! |
Sounds sweet.
Very similar to what I'm building. Which of the Magnaflow cats did you use, the 94047? 2" OD tubing from the manifold to the cat? How far is the cat from the manifold?
Welcome to the 4.11/4.44 club!
-Chike
How did you replace the front hubs? I need to swap out my abs ring. any suggestions/steps and tools to use? anywhere I can rent it from?
when I first installed my exhaust system without the middle cherries (only the high performance dual end mufflers), all the ground was shaking, even when i pass near cars, all their alarms go on.... then I realized I should calm the beast, so I put the cherries, and i have now like BMW M5 sound.. veeeerrrrrrrrrry niiiice
Current: 2005 Black Legacy 2.5i 63k Previous: 1996 Brilliant Red SVX LSi 117k |
Well from the headers back it is dual 2 1/2" straight pipe then behind the (don't forget this is 2wd) Tranny it goes into a two into one 3" pipe. Then it has a magnaflow race muffler than a standard high flow which then splits into dual once again for the finisher of two dual square tips. It sounds mean. Very close to stock at idle until you get past 1100rpm then it just sounds very twin turbo porschey. Although now i have everything complete and toke it on test runs today. The heat sheild seems to rattle around 3000 to 3500rpm, otherwise than that full throttle at 25-30 mph breaks the front wheels lose into a torque steer monster. LOL. man i can't say enough about getting gears in this car, i change the whole feel of the car. The car seems to just shifter better, response is like day and night, and when you kick it down to pass or just whatever, it just plain goes!! Love it to death. Next up is the stage 2 computer, upgrading the brakes, and finishing the tunes. This car may be for sale soon, i know i know why, but i've had my sites set on a wrx. I vowed that i was getting one this summer so projects are getting finished and booted so i can go plunk so cash down for one. But you never know, i might decided to keep this and still get the wrx. Love my svx!
Hubs...
Ya i can admit if you don't have a presh those hubs are a bit of a pain. I had to use our tubing bender with some jerry rigged plates to hold the spindle and presh the race out with a pipeexpander adaptor. The hub actually pounded out with a large socket, although the bearing and seal where still attached and end up very careful grinding it down until it was easy enough to come off.
Lmao, presh......press that is.
Im not too sure thats gonna happen though unfortunately mychailo...I have 2in pipes going into a high flow magnaflow cat 2in in 2.5 out to a flowmaster. There is no resonator and it resonates like crazy right at 3000-3900 sounds horrible. This made me believe i needed a resonator. Now your saying you basically have the same thing except I have a cat and you don't and with a resonator the sound is still there? I was planning on just chopping out the cat for now until i have more money for another one because, this one was shot in aproximately 4months. However i have been throwing a 02 sensor code the whole time so i was running rich.I still can't believe it toasted the cat that quick though. Either way i was gonna chop the cat and run dual straight pipes till i fix it, might be a little louder but it can't sound any worse.
Well that's lousy news. Yep. I've got a resonator in there but no 2-into-1 cat. Seems that we have the same sound. I guess I'm going to have to change my game plan again. elninoalex said that he got good results by placing resonators in the primary pipes before the y-pipe/2-into-1. I may have to go with that setup afterall. At least you saved me the trouble of determining this the hard way.
i wish it werent true but i guess it saves us both in the long run....Do you think cutting the pipes will make them too short and have possible problems with my valves getting burned?
