Old 01-07-2005, 10:30 PM
How harmful (if at all) is WD-40
to my acessory belt?
I figured I have a pretty bad belt squeal and it annoys the neighbors so I had better get rid of it.
Before I can actually replace anything I ofcourse am going with a quick fix.
I guess that since they only squeal below freezing the reason they do so is from frost build up.
WD40 to my knowledge disperses moisture.
So I spritz some on the ribbed side of the belt.
Not much.
Just a quick squeeze.
After a second the frost disappears (from vision) and the squealing stops.
I am also under the impression various flammable petroleum based products eat away at rubber.
I know these belts are tough, but I'm wondering how tough and how long a belt can hold out using WD on it every day (I've only done it twice, ever).
My long term plan is to find a belt that can fit the underdrived pulley.
Old 01-08-2005, 05:46 AM
Re: How harmful (if at all) is WD-40
<Mr. Obvious>maybe you should make that a priority as opposed to a long term plan.</Mr. Obvious>
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 01-08-2005, 08:17 AM
wawazat??'s Avatar
Yeah, I'm still around
I agree with Alan. Petrochemicals are bad for many grades of rubber. Fixing the problem is better than creating another problem in the future.
Todd
Down to none
Old 01-08-2005, 09:31 AM
They sell belt dressing for that purpose. I would avoid WD-40 for the reasons already mentioned. Maybe it is time for a new belt.
Old 01-08-2005, 09:47 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Serp' belts typically don't respond well to any type of dressing. They don't have the same level of pinching action that v-belts do.
Old 01-08-2005, 10:46 AM
Mr. Pockets's Avatar
Moderator
Your belt slips and squeals because it's the wrong size, so you want to lubricate it?
Come on, Nik - just get a new belt!
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-08-2005, 02:00 PM
Beav's Avatar
Not as old as Randy
Nick, Nik could just loosen the belt a bit, pinch up some slack and run a sheet metal screw through it to make it shorter, maybe even use a pair of vise-grips... (what a visual)
Old 01-08-2005, 06:09 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Agreed. WD-40 on a belt is a big no-no!
-Chike
2006 Steel Gray WRX TR (sold)
Old 01-09-2005, 05:32 AM
Got a new, shorter belt today er, yesterday (long night).
Mr. Obvious -> I worded that wrong. What I meant was my long term fix would be to get a new belt, not make it a long term goal to eventually accomplish.
Old 01-09-2005, 06:45 AM
from your previous posts, i wouldn't be surprised if you made your own belt out of band-aids and a hot glue gun.
Old 01-09-2005, 11:01 PM
Weasel 22
hmmmm question if I may...waits...alrighty then..I will proceed..my SVX is all stock and my belts look good..no signs of bad wear..its been very cold and wet here..and she squeals when I start her for the first time and occasionaly even after having driven around..how easy is the accessory belt to tighten?
Old 01-10-2005, 12:19 AM
Firstly you shoud have two, unless you took out your A/C like I did.
Secondly there is an idler pulley under the PS pump with a bolt sticking out. You tighten/untighten the bolt which moves the pulley which tightens/untightens the belt(s).
Old 01-10-2005, 12:41 AM
Weasel 22
most appreciated!
Old 01-10-2005, 01:26 AM
Not much.
USE tranny Dextron III. all mechanics over here in this situation...
Old 01-10-2005, 06:02 AM
I'll give that a try for the sake of experimentation.
