How hard is it to replace the transmission???
Hi Everyone
My 92's transmission just went out on me, it started to slip at 4th and now it starts to slip 3rd. The first and second gears are still ok, the svx is still driveable, but I dont think it will for long. There is a 96 Legacy outback in the junkyard with a good auto transmission and diff, I am wondering if it is hard to replace my transmission? Is it mainly bolt on operations? How long will it take? I've never replaced transmissions before, so any input will be helpful. If it is not feasible, I think I might just part it out. Please help! 92SVX auto with 150,xxx miles |
I replaced mine in the garage with the car on jackstands one weekend. It isn't too hard to do at all.
The hardest part for you will be swapping the ring and pinion in the rear diff and getting the gear alignment right - but you could always take that to a shop separately.
^^^^^ What Matt said.
I did the same. Search 4.11 and 4.44 and read the threads, look in the lockers referenced. It's big & heavy, but I managed by myself with a tranny jack, some jackstands, etc. However, only you can judge your confidence/skill level. I'd guess that if you've changed a timing belt you could do the tranny. If the extent of your mechanical knowledge is changing oil then I would want access to someone with some skills (just MHO). |
Thanks for the help
I was able to change the timing belt, water pump, cam seals, oil pump on my other 93 Impreza AWD. I guess I am alright to do the transmission job. Where can I get a transmission jack? I have never seen it before?! I will need it because I will be doing this by myself. I thought the rear diff. is a bolt on operation. I quess I still need to swap out the guts. Also I thought the 96 Legacy outback is 4.44??? Thanks again |
You can get a tranny jack from sears, or northern tools. harbor freight, etc. Google it for a picture of one.
I actually used a regular floor jack and I would not recommend trying that - it was ugly. You need to swap the guts out of the diff so that you can still use the svx axles and limited slip.
I also used the same tranny jack to lower and raise the rear diff...it's a hefty little thing when you're on your back on the garage floor. Last edited by lee; 01-02-2005 at 05:09 PM. |
I really appreciate the information you gentlemen provided. I will check with the junk yard tomorrow about the pricing. I will keep you updated.
Thank you very much!!! |
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
The best way to tell is the rear diff is a swap out or not is if the opening in the rear diff is completely open. The LSD has an no center pin were the input shaft go. I.E. that is why the right SVX shaft has a longer input shaft then the left side.
I did a 96 Impreza tranny swap & ring/pinion. PM if you need and other help. There are pic in my locker too. Most important is to ad a tranny cooler and filter with this swap or you will be doing it again. Steve Tranny swap info. Pics
92 SVX AWD 130,000 w/ rebuilt SVX 4.11 97 Audi A4 1.8T (Daily Driver) 03 Ford Expedition(hers) SVXepidia SVX information warehouse Are you in? My Old Locker A 4.11 Founding Father "Tranny #6" I really need a manual Reading IX [SIGPIC][/SIGPIC] Ya I was there
I replaced the transmission in my SVX myself - it sounds to me like you can handle it.
As for the tranny jack, I used an ATV / motorcycle jack I bought at Sam's. It has a really wide footprint and folds much flatter than other tranny jacks I've seen. Pictures in my locker.
Thread Tools | |
Display Modes | |
