Old 01-01-2005, 10:08 PM
97LSi004's Avatar
97LSi004 97LSi004 is offline
wiring diagram
i know wiring diagrams have been posted in the past, but i can't seem to find one for a 1997 svx.. i'm installing an aftermarket alarm with remote start.. i've read a few threads on the topic, i want to know the ignition switch wires, all black with certain stripes.. any help is appreciated.
-Ryan
My first Subaru, 1997 LSi #004 - SOLD!
Currently driving: 2002 Honda Insight, > 60MPG!
Old 01-02-2005, 08:07 AM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
the svx is cake:
12volts - black/yellow (+ ignition harness)
Starter - black/white (+ ignition harness)
Ignition - red (+ ignition harness)
Accessory - red/yellow (+ ignition harness)
Power Lock - orange (- center console switch)
Power Unlock - orange/green (- center console switch)
Parking Lights+ - red/white (headlight switch)
Door Trigger - white/red (- underdash light)
Trunk/Hatch Pin - yellow/blue (- light in trunk)
Tachometer - yellow (ECM)
Brake Wire - white/red (+ brake pedal switch)
Horn Trigger - green/black (- steering column)
When I did mine the ignition wires disconnect at a connector. From the connector back are the color listed above. From the connector up to the steering column they are different. So be sure to take note of the color changes at the connector. There's only 4 wires so it shouldn't be that difficult.
Also for parking lights it can be found at the fuse box, or even at that little "P" parking light switch on the dash - nice and easy.
Good luck.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 01-02-2005, 09:20 AM
97LSi004's Avatar
ok, so i'm almost finished, my unit has two wires for parking lights, one for the red/white connector you mentioned (the instructions say "Parking Light Relay Output"), another for the "Parking Light Relay Input", and as i can see we have switched ground parking light circuit on svx, is that correct?
in that case it tells me to connect it to ground
-Ryan
Old 01-02-2005, 09:21 AM
97LSi004's Avatar
never mind, i realize what i am doing wrong now.. thanks for the help rmjjenson
-Ryan
Old 01-02-2005, 09:24 AM
rmjjensen's Avatar
yeah guess u figured it on - give the relay input +12V ........so which audiovox/prestige unit did u get?
