Old 12-17-2004, 12:14 PM
TorG0d
Hella.
I got a new tranny sent from Subaru for $4k when mine went out. How would I be able to tell if I got the VTD one or not? I mean, for $4k and only a 15k mile warranty I'd better have.
If not, how hard would it be to install the VTD center diff while keeping the same everything else? Could this be done by just removing the rear driveshaft?
Old 12-17-2004, 12:21 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Originally posted by TorG0d
Hella.
VTD would require a different TCU. I doubt you got that. I don't think you can just install a VTD center diff.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 12-18-2004, 01:58 AM
Originally posted by Mr. Pockets
Then stop blaming the car. It's as simple as that.
I think everyone proved here that tires weren't the issue.
Old 12-13-2005, 03:20 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
I thought only the STi got the locking center differential... Ive had my driveshaft out and I havent seen a center differential yet
And yes open differentials seem not to make any sense.. sending the power to the wheel that has no traction but thats an open differential, its why they make vicous and locking differentials...
Im used to my svx only spinning one front and one rear wheel... its like having 2wd but it can pick which 2 to spin... the two with the least traction...
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 12-13-2005, 03:29 PM
Word to Yo Motha
ten characters.
Collin
1995 L AWD
Locker
Old 12-13-2005, 03:32 PM
Word to Yo Motha
If it is only spinning one rear wheel, your limited slip is malfunctioning. That, and it is a weak limited slip to begin with.
Open diff is cheap, simple, and generally goes around corners better. It allows the wheels to turn at different speeds. High percentage locking limited slip in the front will cause the tires to chirp because they only want to go in a straight line at the same exact speed.
Collin
1995 L AWD
Locker
Old 12-13-2005, 03:36 PM
Ok Lets get one thing straight... The SVX has a limited slip rear... this means the rear wheels SHOULD spin at the same (or close to) rate. The front differential is open... which means one wheel can spin while the other is stopped. Diff 101
The (center diff) transfer clutches are of active control design. They are powered by Sol. C in the transmission to react and send certain amounts of torque to the rear wheels based on conditions monitored by the transmission. If you Sol. C is broken or has failed, you could end up with the clutches fully engaged or fully open. Fully engaged will cause a binding in the driveline while fully open will allow for 0% of torque made to go to the rear wheels.
With that said, if your rear wheels were no help but they did have traction, that means the transmission was not putting any power to the rear wheels... and with what I just mentioned, who can tell me what that means?? Thats right!!! The transfer clutches are not working properly!!! Now do some research and find out which symptoms of which problem matches yours the best and go from there with the repair
Old 12-13-2005, 03:45 PM
Originally Posted by SVXer95
Center=front. It may help you understand if you use this some more:
No the center diff is what splits power from front to rear. Front is what puts power to the axles...same for the rear. All Subarus that have AWD have 3 differentials
Old 12-13-2005, 03:48 PM
Boxer6SVX's Avatar
My front dif just locks and unlocks very loudly and hard... to the point that i thought Id ripped my transmission out... as it rolls in gear it will lock up and almost stop the car... is that Solenoid C doing it or have I mechanically screwed something up? Under power breaking it will slip as in Neutral and then pop in... once again solenoid C or is it mechanical?
1995 850Ci
Old 12-13-2005, 03:52 PM
No, your differential has probobly grenaded and looks like a box of steel cereal right now. I just did a front diff rebuild for a guy who broke 3 teeth off of his pinion gear..
Old 12-13-2005, 03:53 PM
Word to Yo Motha
pwn3d by you and myself.
Collin
1995 L AWD
Locker
Old 12-13-2005, 03:54 PM
Boxer6SVX's Avatar
but at 5mph it did that? Given it has seen additional stress from being FWD for a month but at almost a standstill it decided to do this? lol
1995 850Ci
Old 12-13-2005, 04:00 PM
Boxer6SVX's Avatar
When someone says center dif I think of a separate differential like the one in my dads truck located between two driveshafts behind the cab. front dif I think of a differential fed power from a driveshaft with two axles coming from it, same with the rear. Simply put I think of a truck setup... 4WD when I think center differential.
1995 850Ci
Old 12-13-2005, 05:06 PM
n00b on demand's Avatar
hahahahahahah
Old 12-13-2005, 05:28 PM
Boxer6SVX's Avatar
hahahahahahah
The repair guy more or less looked like he wanted to cry when I told him it was an SVX with the 4EAT and awd.... poor guy... just glad its not me.
1995 850Ci
