Old 12-09-2004, 07:50 AM
Originally posted by red95svx
You can doubt all you want. I've seen it first hand. More often than not an engine that runs rough at low RPM has some sort of intake/vaccuum leak.
ok man, cool down, ok that was the problem, the gaskets. anyway I am happy the sputtering is over...
Old 12-09-2004, 07:51 AM
n00b on demand's Avatar
Happy 1000 dave!
Old 12-09-2004, 08:02 AM
red95svx
1,000! WOOOHOO! I'm taking the rest of the day off
Old 12-09-2004, 08:05 AM
SilverSpear = red95svx/2
Old 12-09-2004, 03:18 PM
oab_au oab_au is online now
A leaky intake gasket will allow extra air into the intake. This in turn will cause a leaning of the air/fuel mixture (since the air is coming in from a point that is beyond the Mass Air Flow sensor, the ECU doesn't "see" it and therefore doesn't compensate for it). This lean mixture causes roughness at low RPM. However, as the RPM's increase, the air/fuel mixture is enrichened to the point where the small intake leak is not enough to lean it out. So the engine runs smooth. That's my guess, anyway.
Gee Dave thats a bloody good diagnoises for a 'Spare Parts Assistant'. you should move into the workshop.
I agree with you entirely.
Old 12-10-2004, 06:55 PM
Htownsvx Htownsvx is offline
Send a message via Yahoo to Htownsvx
so i think that dave won that one!!!!!!!
so dave you think it it a gasket ??
i have check all the vachum line 3x.
im going to changed the fuel filter just because the thing does have 100,000 miles now and it is going to go bad anyway here soon.
how much do a set of head gaskets cost???
or what could i do to fine out if it is a gasket leak???
01 subaru legacy 5sp
97 J-spec kl-ze 5sp ford probe
the best of them all the 92 lsl svx amost 100,000 mile
Old 12-10-2004, 08:09 PM
Old Fogey
Let's see....... quantity vs quality? I watch for Dave's.
Glenn
apologies for previous caustic comment.
spudering? Is that when my SVX spews mashed potatoes from the intake??
Old 12-11-2004, 06:20 AM
red95svx
Thanks for the positive feedback guys....I appreciate the nice comments
I wasn't trying to "win" anything though....just having a friendly disagreement. If I came across as trying to be Mr. Know-it-all I apologize. Sometimes my sarcastic behavior gets the better of me.
Old 12-11-2004, 06:23 AM
red95svx
Thanks for the laugh Glenn. Working on a Saturday stinks, but starting it off with a good laugh really helps
P.S sent you a PM
Old 12-11-2004, 07:38 PM
awdsvxh6's Avatar
awdsvxh6 awdsvxh6 is offline
Send a message via AIM to awdsvxh6
mine would spudder some times when i was going and at light it would do the same thing and sometimes stall but still no light. we hooked up a select monitor for the 92 svx and it said cam sensor so i changed the one next to the battery and it still did it the i changed one of them under the alternator and i havent had any problems since
Old 12-13-2004, 01:02 AM
so at the end it was a cam sensor... neither a weak valve nor the gaskets... and as Dave said it was a friendly disagreement.. I wonder I didn't have any symptoms since the thing I did with the engine, but maybe in the future I will experience the same phenomena... and Rocket, let me tell you something, I do not consider myself as a mechanical expert, I know a great deal of everyday's mechanical symptoms, but I do not consider myself as a mechanical engineer. maybe an SVX certified plastic surgeon... still though, I am proud of my knowledge...
Old 12-13-2004, 08:39 AM
Old Fogey
Spear,
That much is clear.
Glenn
Old 12-13-2004, 09:37 AM
red95svx
I guessed gaskets because he said his check engine light was not on. Assuming his check engine light was working, the lack of a light would rule out an electrical problem. So his case is truly strange....a bad sensor but no check engine light.
Weird!
Old 12-14-2004, 01:52 AM
Weird!
what about what happened in my condition??? i had the same sputtering !!! but not anymore. the sputtering goes for 5 seconds... really Weird !
