Old 12-04-2004, 01:19 PM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
High RPM's
For some reason my RPM's have been at about 2000 when I put my car in park or neutral and about 1500 in drive. Earlier today i was idleing at about 42 mph. Any suggestions?
Teal 92 SVX LS L with 103k
Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks)
Old 12-04-2004, 01:54 PM
n00b on demand's Avatar
TPS? .....sometimes when i put my car in park it idles at 1000....i give it some gas..needle jumps and goes back down to normal idling.
Old 12-04-2004, 04:53 PM
GJSVX
Same here, sometimes it will idle high for a few seconds and go back to normal but if not a little press on the gas usually does it
Old 12-05-2004, 12:24 PM
rob_4187's Avatar
You're mine!!
I can drive accross town and when i stop at a light i put it in neutral and it shoots back up to 2000 rpms.
Old 12-06-2004, 07:07 AM
TorG0d
Almost sounds like your "choke" is staying on.
Old 12-06-2004, 04:20 PM
If you adjusted your TPS or IAC then it may take a few starts before normal idle returns.
Do you have a 5spd?
Old 12-07-2004, 10:09 AM
rob_4187's Avatar
You're mine!!
Didnt touch anything. It just started out of nowhere. I have an automatic.
Old 12-07-2004, 10:32 AM
For the past 3 days now whenever i put my car in park the rpms stay just a tad bit below the line for 1000. It goes back down to normal idle after about 5 or 6 minutes. This is with ECON on with the temp set at 80...setting to HI. Happens with econ off too i think.
Old 12-07-2004, 11:00 AM
rob_4187's Avatar
You're mine!!
Well its going to the shop now because i went out and started it and left it in park for about 30 sec and the rms were going 1000-1500-1000-1500 and so on. The check engine light came on so i turned it off and started up and it didnt do it so I rode around the block, then put it in park and it did it again. it does it in neutral too.
Old 12-07-2004, 06:12 PM
check all your hoses under the intake and such. these could fall off and effectively mess up all vacum related systems.
