How Long do you warm up your car?
Ever since I got my autostarter it's gotten way more convenient. I get dressed and eat breakfast. Then I start my car from in the house and go to brush my teeth, do my hair and wash my face. After I'm done with that I head out the door to see my car idling at a nice 750 RPM with the heat on (warmed up 5-7 minutes) and I drive off.
At the end of the school day I start my car from the other end of hte parking lot (it will reach as long as I can see it even in the distance) and I walk slowly and then I get to the car. I pull away as long as my RPM reaches 1000 or below (average of 5 minutes of warming up) What do you guys do?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
I usually go for 1 minute, then drive gently, keeping the rpms below 3k and not driving too fast till it's fully warmed.
-Chike
From everything I've read letting a modern car idle to warm up is actually more detremental than getting in it and driving like the Bandit (aka Burt). Older carb cars tended to drive poorly until warm but the fastest way to warm an engine (ie the oil) is to drive it at moderate engine speeds after a few seconds of warm up at idle (which is more for the transmission to get its pressure up more than anything). Is your car gonna die this week? Probably not unless Green1995SVX has been lerking about! Will it take some of the life of the car? Probably but how much is the question and is it worth a few thousand miles of engine life compared to the convinence for you?
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
I always let the car warm up to full operating temp before i take it out. But once the needle starts movin its ok to drive.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Driving a cold block like a bandit is a good way to blow some head gaskets or warp some heads.
In the winter, I usually warm it up until the cabin heater clicks on. In the summer, I usually warm it up until I see the needle on the water temp gauge start moving. Usually ends up being at least 3 minutes.
i did miss your point, but now i see it.
you guys are in cold areas what about here in cali when its constantly hot how long should we warm up the car!
In general its ok to drive the car once the temp needle starts to move. Just dont drive it hard untill its fully warmed up.
Warming up
Hi everyone, My SVX is always stored inside but what I recommend no matter the ambient temp is #1/ Start car{Do not touch gas pedal before starting } #2/ Let idle for 15 to 30 seconds. #3/Drive off using light throttle untill engine is warmed up. On the SVX, the tranny will not shift into Fourth untill the trans fluid reachec 50F degrees and will not lock up till it reaches 160F degrees. Your good to go! Take care, BOBB
P/S In extreme cold temps[below zeroF degrees] you may have to give it some gas when starting. "B" |
I do this:
I get out of my house. Get in the car. Start it up and back up. Then move out and hit the gas. The car has 180+ and worst case, I'd be replacing an engine (which i was going to do anyways) so...
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
Benebob is correct. Today's ( & most of yesterday's ) cars don't need any elaborate warm-up ceremony. As long as the engine isn't "raced" after start up, summer or winter, a few minutes of "gentle" driving is better than 5 minutes of steady driveway idling. The reason, I believe, is that ALL the driveline components should be gradually warmed, not just the engine. However, it's probably wise to avoid burnouts until the car is fully warmed.
Ron (spoiled by a garage).
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
no warming here.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
