Old 11-11-2004, 08:09 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
Re: The way I see it
Originally posted by Beav
You're right, it is on the right side, but that's why it's wrong.
If the vast majority of humanity is right-handed isn't it more logical to keep your right hand on the steering wheel, leaving your left hand free to do more mundane tasks such as flick cigarette ashes, pitch empty beer bottles and empty wine boxes out the window?
hahahaha driving drinking and smoking. are my favorite things to do. to bad they dont mix. stupid intoxication affecting judgement and motorskills. stupid, ugly women looking hot while drunk. KHAN!!!!
like the green looks better than my polo. maybe a stock spolier would help.
Old 11-11-2004, 08:40 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Red car going - sad day
Originally posted by grnSVX96
Chiketkd
It will be a sad day when I finally let the red car car go...it has been a real attention getter...much more so than the green car with the same wheels fitted...says a lot for RED cars !!!
It definitely does say a lot about red cars. Whoever gets the red car will be a lucky person...
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-11-2004, 09:03 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
The rims make the car look very aggressive...
I like it!
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-12-2004, 07:55 AM
grnSVX96's Avatar
grnSVX96 grnSVX96 is offline
ex SVX owner - still keen tho
Chiketkd - just for old times sake !!
sorry to indulge..
The green looks good ..the red well ..great !!
Hey do the comparison ..aahhh modern technology...!!! so many choices ..but one has to go...
Thanks for the comments all
Dave Down Under
Old 11-12-2004, 09:15 AM
Chiketkd's Avatar
Thumbs up
Damn. Both of those cars look amazing! The wheels just really accentuate the lines of the SVX very well...
-Chike
Old 11-13-2004, 07:54 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
i like the wheels... what are they and where did you get them? what size/backspacing are they?
Old 11-13-2004, 09:49 PM
grnSVX96's Avatar
Wheels by Koya - detailed
"Freak customs"..here you go..
18x8s 235/40x18 fronts - 35 offset
18x9s 265/35x18 rears, with 40 offset
Wheels type is Inox 2 by Koya ..wheel is a multi spoke deep dish with stainless steel lip..with deeper lip on the rears ... 9s..tyres were Falkens [non directionals] and the wheel tyre combo was AUD$2600 all up, so thats about $1300 - $1500 USD
[fairly easy to clean as well]
Sizings as comp'd to std SVX
Tire size results
Specification Sidewall Radius Diameter Circumference Revolutions Difference
225/50-16 4.4 in 12.4 in 24.9 in 78.1 in 811 / mile N/A - std
235/40-18 3.7 in 12.7 in 25.4 in 79.8 in 794 / mile 2.2% - front
265/35-18 3.7 in 12.7 in 25.3 in 79.5 in 797 / mile 1.8% - rears
here's a side shot of the wheels when they were on my red car..
NOTES
Now to accomodate the 9 s in the rear as there was slight rubbing [raised lettering on outside tyre wall catching on wheel arch black plastic/rubber strip in heavy cornering][no damage tho to the tyre or the strip]...camber kits were fitted, in this shot you can just see the effect as the rear wheels were 'pulled in' at the top..compared to the fronts..its by no means aggressive which I have seen [look stupid] on cars where they have struggled to get the wheels to fit..the camber setting at the rear is close to the same used on WRX as my wheel alignment guy owns one himself [WRX] and has played with his to tweek his handling
and a bonus was handling seemed even better...more rubber on the road as well..same corners now in the red car now with std rims, the tail seems to move around more, but the ride is a bit softer ...I also adjusted tyre pressures front to back so the "rolling diameters" were the same ..factory is 10% more in the front than the back [32psifrt/29psi rears], anyway ...do a search on it there has been much discussion, I ended up and still run on these rims 40psi front and 29psi rears..
Thats it
Hope that helps
Dave Down Under
Old 11-13-2004, 11:23 PM
Chiketkd's Avatar
Dave,
What are your alignment specs?
Camber?
Caster?
Toe?
Thanks!
-Chike
Old 11-14-2004, 11:05 AM
everything i needed to know... thanks
Old 11-14-2004, 02:03 PM
grnSVX96's Avatar
Question Chike - specs
I think I've got that on a printout from the alignment guy after he refitted the wheels and camber pins on to my green car, and the sheet's in the car and the cars in the shed, so I'll dig it out soon, try a scan and PM it to you
Dave Down Under
Old 11-14-2004, 07:46 PM
Chiketkd's Avatar
Thanks Dave. Sounds like Freak Customs might be interested in the specs as well so please post in the thread.
-Chike
