Old 12-18-2001, 07:19 PM
Joe 90's Avatar
Joe 90 Joe 90 is offline
Canadian eh!
Unhappy noisy power steering pump...Help!
Hi guys.
It's getting cold now up here in Canada......
....And my power steering pump is quite noisy when I first start the car in the morning (brrrrrrr!). After warming-up for a while, the noise disappears.
I checked fluid the level and it's fine.... My guess is that the noise is due to cavitation (air bubbles) inside the pump caused by some worn O-ring(s), which is amplified by the cold weather....
Has anybody experienced this before??? What was the fix ???
Thanks for your help.
Old 12-19-2001, 04:59 AM
svx_commuter's Avatar
Air getting pulled thru a hose hole or thru the "O-ring" at bottom of reservior. Gets worse when it gets colder outside cause the fluid gets thicker.
Old 12-19-2001, 09:03 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: noisy power steering pump...Help!
Originally posted by Joe 90
Hi guys.
Many of us have experienced this before. It's an easy fix:
http://www.subaru-svx.net/photos/files/How-To/1334.htm
NOTE TO ALL: The "How To" personal locker holds a wealth of information and is something of an answer to FAQ's. Bookmark it, or place it in your mind that it is available. It's a super source of info. I don't mind re-posting things over and over, but, please keep the "How To" locker in mind.
Randy Johnson
Mike Davis -- at Reading VI
Old 12-19-2001, 12:21 PM
sith
http://www.subaru-svx.net/photos/user.php?How-To
Thar be a link direct to the locker, now you've got no excuse not to bookmark it! Do it! Do it now!
heh.
Thanks for your work on that aredub, it's definately come in handy.
Old 12-19-2001, 12:26 PM
Aredubjay's Avatar
Happy to do it. I've been cleaning up the 5-Speed Laundry list and install pages. Once I get 'em all purdy, I'll post them. Trouble is, they're on my home computer and I'm stuck here at work. Oh well, it pays the bills . . . well, sometime.
Randy Johnson
Old 12-19-2001, 01:48 PM
oneothefewproud
Good thing I thought of it. Randy you've done well my son.
Ciao
Wayne
BTW. My O-ring fix should be in the how-to locker.
Old 12-19-2001, 03:17 PM
Joe 90's Avatar
Canadian eh!
Thank everyone for your help!
I've ordered ALL the seals and o-rings and I'll be doing a complete overhaul of the pump this week-end.
Joe 90
P.S. I didn't know about this "how to" folder.... I'll keep it in mind!
If I come up with a cool fix, can I post it there???
Old 12-19-2001, 03:51 PM
Aredubjay's Avatar
Joe, only Admin can post to the "How To," but, if you come up with something good, just PM it to me and I'll post it.
Randy Johnson
Old 12-20-2001, 09:36 AM
Lowered SVX
i just replaced my power steering pump....
fluid was leaking and it was all gummed up. $330 from subaruparts.com.
"Too much fun to drive!"
Old 01-05-2002, 11:47 AM
Joe 90's Avatar
Canadian eh!
noisy P/S pump
Hi everyone,
Just an update on this issue, I overhauled the pump last week, changed ALL the seal, O-rings and the bearing and the pump is now reunning like new Total cost.... About $45 CDN
Problem solved
Joe 90
