Old 11-01-2004, 09:14 PM
RobSVX
New guy with a few ?
HI !
I'm new here:
1995 Polo Green SVX LSi AWD with 94k miles.
I'm not surprised the cam covers leaking since they lay flat, but can't see how to pull them off since they'll hit the frame rails once I pull them off ? I bought the seals, but what is the trick since it seems the cam gear bump on the cover won't clear. Not even sure about the bolts coming out. Suggestions ?
Also, my 'out temp' light is out. Is that section of the dash removable ?
Thirdly, who makes an easy to install tranny cooler since I understand they overheat and crap out really soon ?
Thanks folks,
Robert
Old 11-02-2004, 08:41 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I know two are covered already - use search for 'immortal suby & gaskets', then 'cooler install.' Regarding the outside temp issue you need to be a bit more clear what you mean - does the display not work or is it the button itself not lighting up?
The covers come right off with a little jiggling, I've done a few sets and they aren't as difficult as one might imagine. Hopefully you also purchased new sealing washers, many times they are the real culprits.
Old 11-02-2004, 09:56 AM
RobSVX
The actual light bulb that illuminates the words ' out temp' is out. Its in the panel with all the buttons. NOT the actual digits, but the little bulb that lights the button to push in the array of 9 or 12 buttons...
Old 11-02-2004, 03:18 PM
Beav's Avatar
Not as old as Randy
I think you may find a few notes on the panel if you search, I seem to recall reading about it some time ago. There are a couple bulbs listed behind the panel but I'm not certain if they are what you need. Once apart most bulbs and/or leds are available at Radio Shack.
look here:
http://www.subaruparts.com/diag/?mod...ategory=723-A1
Old 11-02-2004, 05:17 PM
immortal_suby's Avatar
Thread Killah
Originally posted by Beav
I know two are covered already - use search for 'immortal_suby & gaskets', then 'cooler install.'
I'm famous!
or is that notorious?
Locker Link
2015 BRZ Limited 6MT
Old 11-02-2004, 06:25 PM
Beav's Avatar
Not as old as Randy
Not sure which but I am sure my neck aches whenever I see your avatar.
BTW - go ahead and give yourself five bananas, you deserve them.
