For some reason this seems to happen mostly with WRX swaps. The relay trick worked great for me.
In the four times I've started my car since setting this up an hour ago, the relay has worked flawlessly. Thanks for the clue-in!
Front to back, sorta: Claret 1992 Subaru SVX LS-L, JDM STi open front diff six speed, STi tranny mount, Kartboy shift bushings, WRX CD changer, rear R180, battery in trunk, Stebro exhaust. 2000 Specialized RockHopper A1 FS, converted to singlespeed 36:15. I like my cars with too many gears and my bikes with too few... |
what size wire will work?
I need to put the relay unit in for the starting problem. What size wire works for all the connections. Do I need special connectors. I only seen 10 gauge as the largest at the auto parts store. I need as many details as needed. Thanks in advance.
Mike
95 Pearl Blue L |
Go to NAPA, use the part number I listed. Tell them you also want some 14ga. wire (2' will be more than you need), 6 female blade type terminals to fit the relay, 1 - 3/8" ring terminal and 1 - 1/4" ring terminal, all terminals 14ga (blue).
I tried to look up a relay socket/pigtail @ Autozone.com but, just like their parts, their website was phhhhhhhhhhht. You don't need one, I just thought it might make it easier for you instead of crimping up the terminals. Get some electrical tape also (or shrink tubing), to insulate the terminals.
Starting solution
Thanks Beav for the timely reponse. I'll get these items rounded up and within a few days post how it went.
Mike
95 Pearl Blue L |
Don't go too cheap on the relay!
My initial mod was initially only a partial success because the relay that I used, although brand new, was junky (freebie PIAMM air horn relay that came with my $20 air horns) and when it got hot, it starting shorting closed, sending a start signal to the solenoid, causing my starter to engage while the engine was running.
I went to NAPA and looked through the entire relay book and found what I think is the one that is rated for the heaviest duty. It is NAPA AR204 (AR stands for Accesory Relay). Most relays are rated for intermittent use (horn, wiper washer pump, etc.). This one is rated for continuous duty like an AC compressor. Better internals cost money and this relay set me back $17, but my problem is cured. I know that it's probably overkill to use such a heavy duty relay, but after experiencing my SVX trying to start itself while the engine was running without me twisting the key was enough to make me spend whatever it took to get it right. If you encounter that problem, upgrade the relay. |
Relay Choices
Thanks for that bit of information. I haven't been to NAPA yet. I slept too late today. I may just go with the heavy duty model. Considering the heat here and just another $10 its peace of mind.
Thanks Mike
95 Pearl Blue L |
