Old 10-11-2004, 07:30 PM
87f383's Avatar
87f383 87f383 is offline
03 Wrx Auto
WIll this Directly swap into my 95 AWD SVX... by directly I mean both mechanically and electrically. If so, I will purchase this as my SVX hates me right now and has a whinning diff. Dear god I hope it will.
Old 10-11-2004, 08:28 PM
May be.
I think that this model would have the later box with the brake band replaced with a clutch. If it is, you will need the TCU and the TCU to box loom. the change points will be different.
Old 10-12-2004, 07:39 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Check: http://endwrench.com/images/pdfs/4EAatPh2Win04.pdf
More articles available, search archives for 4eat.
Old 10-12-2004, 10:28 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I'll say this, the WRX auto will bolt directly up to the engine, but the connectors will be very different as this trans uses an updated VTD (vehicle torque distn) system, which wasn't found on pre '99 MY USDM Subarus.
If you do get the WRX auto, get the TCU and wiring harness as well. The WRX 4EAT also uses 4.11 gears, so you'll need the rear diff.
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-12-2004, 10:50 AM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
Question
'99 MY USDM Subarus
What is MY? is that a trim level of Subaru or something
Old 10-12-2004, 10:52 AM
ilsegretosvx
MY=model year
Old 10-12-2004, 11:15 AM
87f383's Avatar
Well, nothing is just simple on this car is it. I don't feel like spending another few K to fix the front diff again. The third time in 2 years. So time to pursue another option if I can't find a donor tranny. RWD!
Drop the tranny take it to a machine shop and have them fab up a solid shaft to replace the transfer clutch assembly and remove my front diff and axles.
AWD is worthless in TX anyways and RWD is much more fun to drive. My firebird is at least.... but then again, it doesn't have a deplorable lack of power like the svx does. (in comparison)
Old 10-12-2004, 11:41 AM
Chiketkd's Avatar
How about switching to 4.11/4.44 gears? You can pick up a good low mileage pre '99 Legacy/Impreza/Outback 4EAT & rear diff for around $600. Puls the added torque in every gear will make your SVX quicker!
-Chike
Old 10-12-2004, 12:03 PM
red95svx
1) The SVX is a sporty coupe......not an all-out sports car.
2) Firebirds, Camaros, and Mustangs are all a dime a dozen. I'll take rare and beautiful over fast and common any day.
Old 10-12-2004, 12:37 PM
87f383's Avatar
I don't consider my 87 Formula 350 Hardtop w/ an GENIII/T56 a common occurance. Hell, by its production numbers it is a rarer formula than my SVX is an SVX. Hell, its wheels are rarer than an SVX.
I also consider it a more trustworthy car in regards of getting me from point A to B (before I took it back apart for its next incarnation, rebuilding the GEN III). The SVX comments are out of spite. But it is in fact a slow car...for its time and now. But a pleasent driving experience it does have.
My front diff has failed like clockwork (3 times in 2 years, that is a considerable exspense over the 20K miles that I've owned the car) and I'm considering converting it to RWD as a viable option. If you have something to add along that path or getting the 03 WRX tranny to work(if I can still get it) Than please let me know.
Old 10-12-2004, 12:40 PM
87f383's Avatar
-Chike
Any good sources for the parts? Subarus are not common in TX, everyone thinks they are ugly and there is no use for the price premium of AWD. I would be interested in doing the 4.11/4.44 swap if I can get my hands on the parts... if not then, I guess RWD is the path ahead.
