Old 09-26-2004, 11:52 PM
nextse7en's Avatar
Graphic Artist
Leaking injector?
Hi there folken' this issue started last night (at least I noticed it last night)
When I started it up a white cloud of smoke poofed out of the back (note, last night it was about 55 deg, I'd imagine it was fairly high humidity) the smoke didn't dissipate for quite a while, just hung out there for about 40 seconds. The smoke continued to come out the back the entire night, though not nearly as dense.
This morning, it happened again - though much less severe - and no vapor came out after the engine had warmed up.
Coolent is clear - I flushed and chainged the oil today - honey colored after 3k
No C.E.L. action - But when I filled up today my milage had dropped about 3mpg from last week.
Could I have an sticky leaking injector? The smoke didn't smell like gas - it smelled like typical exaust.
Help on this would be greatly appreciated.
Thanks.
Patrick.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 09-27-2004, 06:54 PM
immortal_suby's Avatar
Thread Killah
mine and my wifes svx both do this a few times a year at random but if I fill up at a certain gas station here then it will do it for the whole tank. Seems to be more common in cold weather.
I would give it a week and then forget it when it goes away - and maybe throw a can of dry gas in the tank.
Locker Link
2015 BRZ Limited 6MT
Old 09-27-2004, 10:37 PM
gl1674 gl1674 is offline
If it starts right up and it does not smell gasoline a lot, it's not a fuel injector. A single leaking injector will give you hard start problems (occasionally it will not start at all without full throttle).
Old 09-28-2004, 03:10 PM
Hopefully it's not a head gasket leaking antifreeze into the exhaust.
