Old 09-22-2004, 10:12 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Interesting -- $3k for coil-over suspension, $1.2k for the exhaust, $800 for the front spoiler. Wonder how much shipping from Japan would add to these prices?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-22-2004, 10:47 AM
drivemusicnow's Avatar
Poor College Racer
the flatt racing exhaust would be a huge waste of money. especially because hes going to supercharge it, and it wouldn't flow enough for a supercharged 3.3.
The coiloovers might be a good solution, but for half the price, the koni-gc setup seems to work great for most people.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 09-22-2004, 11:07 AM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
I remember reading somewhere that '04 (I think) STi coilovers were a direct bolt on for SVXs. I searched like crazy but couldn't find the post.
Anyway, if that's the case, check out Motorsports Distributing they are the sole North American distributor of Hot Bits coilovers. These aren't cheapo systems but should come in at about half the cost of coilovers from Flatt Racing
BTW, Motorsports Distributing is in Ontario, Canada. Shipping won't be to bad, it was $50 for a set of lowering springs.
Old 09-22-2004, 12:11 PM
ilsegretosvx
If you are going to put coilovers on the car contact JIC/zeal motorsports. They are exclusive JIC and can make a set up for you. The base set-ups range from 1300+. They are well worth it and I have used them on many cars including a 93 Turbo Legacy. BTW they race all types of cars including drift so they know their stuff, not to mention the owner is Japanese and so are many of the people who work there.
Old 09-22-2004, 01:59 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
If he wants a built N/A EG33 and maybe increase the displacement to 3.5 or even 3.7L, the Flatt Racing exhaust would be just fine. If he goes the route of an STI motor or putting a supercharger on the EG33, a 3" exhaust would be necessary...
It would still be nice to have an SVX with a Flatt Racing exhaust though...
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-22-2004, 04:43 PM
nextse7en's Avatar
Graphic Artist
I just located a 20K JDM Engine that will be mated to the supercharger for 1300 bucks. Project SVX SC/R Is undeway! 5 speed search is next.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 09-22-2004, 04:45 PM
Chiketkd's Avatar
So are you going with a 5spd over a 6 spd?
If so, for the power you wish to run, send Mychailo a PM about getting the JDM 5spd STI RA gearset. Those gears will be able to withstand easily over 400hp at the crank. Other wise, a 6spd USDM STI trans would be suitable as well.
-Chike
Old 09-22-2004, 05:47 PM
mbtoloczko's Avatar
sans SVX
Originally posted by Chiketkd
If so, for the power you wish to run, send Mychailo a PM about getting the JDM 5spd STI RA gearset. Those gears will be able to withstand easily over 400hp at the crank....
-Chike
400 hp... depends on how the car is driven. :-) Repeated drop-clutch launches from a 400 bhp motor can kill just about any of the 5MT gearsets that are available.
What JDM motor are you going after? 2.0L?
Mychailo
Visit my locker
Old 09-22-2004, 06:32 PM
svxsubaru1's Avatar
Maybe use a costom front diff and rear end to raise the gear artios of the 6psd.
What were the gear ratios of the r180 that were in the SVX?
Old 09-22-2004, 06:34 PM
It's all in the talk or torque.
Old 09-22-2004, 08:16 PM
nextse7en's Avatar
Graphic Artist
The JDM I've got my eye on is 6 cyl outta a jdm SVX - anyone know if there is an equvilant to carfax in the JDM region? I'd like to look up the Vin of this motor.
I'm thinking of boring over to 3.7L Will this automatically reduce my compression ratio? (I'd like to dial up the boost.)
Can someone offer me some sage wisdom - does subaru make a 5 speed that offers a 4.11 ratio? More power to the pavement without killing economy at high speed.
Thanks so far guys - great ideas.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 09-22-2004, 08:22 PM
wawazat??'s Avatar
Yeah, I'm still around
Why JDM?
No reason to buy a JDM motor when they offer nothing different than the USDM motors other than higher shipping cost.
Boring to increase displacement to 3.7L will require custom cylinder liners (and pistons, obviously) as the stock liners cannot tolerate that significant of an overbore.
Good luck, you'll be a pioneer.
Todd
Down to none
Old 09-22-2004, 08:46 PM
Myetball's Avatar
Mr. Inappropriate
To get appx. 3.5L you'd need .040" overbore and a .25" stroke on the crank. To get 3.7L with only bore is going to be tough. Since you'll need custom pistons either way, you can pick the compression ratio you want.
How much boost do you want to run? There are things you can do to boost a high compression engine without destroying it. However, it takes quite a bit of knowledge, several upgraded parts, and some real good tuning.....not the kind of tuning you'll get from a stock or modified stock ECU. I'm talking standalone here.....cough....cough...SDS.
Where do you plan to get the work done?
EDIT: Okay, I did some number crunching and a .040" over bore and .25" stroke increase will yeild a 3.65 Liter engine. Not bad for such small changes.
To get 3.65 Liters with only an over bore would require a bore increase from 3.815" to 4.0".
FYI, here's a little tool that's free and is by far the best freeware I've ever downloaded. ESB Conversion Utility
Old 09-22-2004, 08:48 PM
mbtoloczko's Avatar
sans SVX
4.11 r&p is no problem. The RS gearboxes have this r&p. 4.44 r&p is also no problem if you want an even lower ratio. Forester gearboxes have this.
Mychailo
Visit my locker
Old 09-22-2004, 11:54 PM
NeedForSpeed NeedForSpeed is offline
If you like this exhaust,
-Chike
Then take a look in mbtoloczko's locker!
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
