Old 08-27-2004, 01:07 PM
sxewhodey's Avatar
sxewhodey sxewhodey is offline
Question Charcoal canister check
Just going through everything after changing plugs and from reading othere post I think that this wire/tube from th bottom of the charcoal canister just plugs in somewhere in the fender, right? Ill put it somewhere for now but maybe someone will know the exact hole it goes in.
Old 08-27-2004, 01:23 PM
Green1995SVX
Pull the hose so it's pointing to the rear of the car. It' line up perfectly with the hole where it goes. It's the only hole in the fender there. You cant miss it.
Mike
PS- It'll fall out again as soon as you go over a few bumps.
Old 08-27-2004, 02:30 PM
sxewhodey's Avatar
mission accomplished
Found it, done. Thanks! Gotta finish with the tranny filter before it gets too dark.
