Old 11-20-2001, 10:27 PM
fongangus
Scratch on taillight!!
I found some scratch on my taillight. It seems cause by hitting on the white painted wall (not by razor type). Is there some way I can remove these scratch?? Thanks.
Old 11-20-2001, 11:18 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Scratch on taillight!!
You could try the "Novus" plastic polishing system. There are 3 products that you use in sequence. The number 3 is a "deep scratch remover." You'd start with that. It would be best if you had a buffer. You'd mask off around the tail light, use the product on a buffer to buff out and smooth the surface. Then, you'd use product number 2, which a "fine scratch remover" to make the surface even smoother. Finish off with product number 1 (without the buffer) to polish the plastic to a shine. The products are available at www.jcwhitney.com . Use their search function and do a search on Novus to find the product. Better yet, just click here: http://qcpp.aol.com/jcwhitney.com__C...D=4528&BQ=jcw2
Randy Johnson
Mike Davis -- at Reading VI
