Old 11-18-2001, 01:13 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
open forum: some info you might be interested to know or discuss?!
Hey guys, this is some msg that i asked 'bout tune-up/oil change from beav in private msg. thought that some of you might be interested to know so i move it over here.
feel free to ask/post, guess beav will reply it very good.
happy thanksgiving!
quote:
SSSVX wrote on 11-16-2001 01:49 AM:
Beav said:
"Tune-ups no longer exist. Most '100,000 mile tune-up cars should have plugs somewhere around 40-50,000 miles"
In the days of Ford Model Ts a complete tune-up included a carb rebuild, engine bearings, etc. Later cars included points, condensors, cap & rotor, adjust carb and timing, etc. Modern cars have spark plugs, some still have spark plug wires and that's about it. No adjustments possible/available. The computer constantly adjusts (or "tunes") the sytem. Double platinum spark plugs can last to 100,000 miles (in a car with computer-controlled ignition and fuel injection) but that just means the plugs will definitely be garbage by then. Long before 100,000 miles the spark plug electrodes will have eroded and caused their gap to widen. This causes the coil(s) to consume more energy in order to fire across the wider gap. This induces extra strain on other ignition parts such as the amplifier (ignition module) that feeds current to the coil(s), the coil(s) itself and the plug wires. If a cylinder begins mis-firing the result could be unburnt fuel in the cylinder washing the oil from the piston and cylinder wall, causing premature wear of those parts and the piston rings. When the rings start wearing then crankcase pressures rise and start sending excess oil mist into the intake system and coating the injector tips with gunk. Now a set of plugs doesn't quite cure anything. Of course this is taking things to their logical extremes, but that happens more often than you'd think...
Remember, extra strain causes parts to go bad earlier. Which would you rather buy, two sets of plugs or an ignition module (anywhere from $250 to $900 + diagnosis and labor) and one set of plugs? The reason the OEMs state extended service intervals is purely from a marketing perspective. It makes it seem like you're getting some real value when you spend $25,000 for a PT Cruiser. What do they care? You're long out of warranty by then.
"Same goes for oil change intervals beyond 3000 miles. Even with synthetics contamination occurs."
Piston rings don't completely separate the crankcase from the combustion process. Some of the combustion gases, which carry particulate matter and corrosive gases, will slip past the rings and into the engine oil, contaminating it. Also engine oil is a petroleum product and as such it is hygroscopic, in other words it attracts and holds moisture. In an engine this moisture comes from the atmosphere and hopefully not leaking gaskets, etc. Combine these two processes with additive package depletion and viscosity breakdown (a term of simplification) of non-synthetic mineral oils (this is where synthetics really shine.) Add in short driving cycles - trips less than 30 minutes of cruising speed where the oil isn't held at a higher temperature for enough time to allow evaporation of non-particulate contaminations - and you end up with poor lubrication. Poor lubrication yields premature engine wear, yadda, yadda, yadda... Let's do the math: 150,000 miles / 3,000 mile intervals = 50 oil changes x approx. $20/oil change = $1000. 150,000 / 7500 = 20 x $20 = $400. $1000 - $400 = $600. I can't remember the last time I rebuilt an automobile engine for $600. I wonder if I ever did...
Cars are now running better and lasting longer than ever due to electronic ignition and injection. It used to be a banner day if your car hit 100,000 miles without a new engine or least a valve job. Now most of the cars I work on have over 130,000 miles and are just on their third set of spark plugs. If people would shorten their service intervals to more reasonable expectations they would experience cars that seemed to go forever, especially with use of synthetic lubes. I'm not going down that road though, synthetics are great, but the price/performance ratio is skewed...it depends on how long you're going to keep the vehicle. With good service most cars will rot off of their wheels before synthetics pay off.
You can move this to an open forum if you think anyone else wants to read it. It's kinda long-winded even though I tried to keep it simple.
Thanx for the compliment,
Beav
>>>beav, i'm interested to know why around 40-50kmiles?
oil change beyond 3000miles, even fully synthetic??
subaru svx site says our oil change recommend is 7500miles?
thanks, beav. you damn cool man for car.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 11-18-2001, 05:38 PM
svx_commuter's Avatar
A guy I work with has a BMW 540i. A very nice expensive car in deed. It has an automatic transmission and synthetic fluid. The transmssion is sealed and has no dip stick. The manual says it is sealed for life It's a two year old car with 80k. He is a commuter also.
Beav,
Thanks again for your information. Just today I was thinking, "Oh boy those Walmart plugs I bought for the OBS are still working great!" I should have changed them at 120k but now I got 145k on them. Time to go check them out.
The SVX has a coil right at each spark plug. What is the advantage of this? Anyway to check and make sure the plugs are firing properly? I was thinking about the days when an engine got hooked up to a SUN machine and the firing sequence was displayed on a screen.
When I replaced the platnium plugs on the SVX they all looked great. The gaps had not changed at all.
Oh I hope your head is isn't getting to large but I really do enjoy reading your posts. Your not the average mechanic for sure. You share what you have learned over the years and explain it very well with excellent writing and communication. I enjoy your humor also. I hope your head has become so heavy you can't hold it up any more
Old 11-19-2001, 09:35 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The advantages behind coil-on-plug igniton are the lack of high voltage wires and that the coil can 'soak' that much longer before having to fire. In other words an eight cylinder engine with one coil fires eight times as much as an eight cylinder engine with eight coils. Not such a big deal at low speeds, but with smaller engines turning higher rpm's to keep up with the big boys it means quite a bit. Who am I kidding? A lot of it comes from the manufacturers not wanting to pay warranty to repair cars for that fail emission testing. It's easier to make customers pay for it up front. If they weren't worried about it, you'd never see it installed at the factory....
Yeah, sealed for life. When it burns up at 5,000 miles past warranty, its life is over. Then you get to pay someone to unseal it, the hard way....
For my money $15 or so and an hour of time isn't that big of a deal for a set of plugs and what they can save me, dollar-wise. I see a lot of burned up coils, caps and wires that could have been avoided if they weren't so stressed by the high voltages required to fire crappy plugs.
Engines still get hooked up to analyzers, beyond the computer scanners. It's just that a lot of places sell plugs, etc. without checking them - physically or with an analyzer. A lot of times that will fix the problem and sometimes it doesn't. On the times that it doesn't they'll call you back and say "While we were doing that we found another problem...' Another way to look at it is the giant analyzers (which can and are being replaced with better designed systems that don't require so much real estate) cost a helluva lot of money. "How much service will I have to do to pay for this $40,000 analyzer?" is the first thought that crosses a shop owner's mind (if it isn't, the only door he'll be opening next week will be the one on the front of the poor house!) The mechanics see it as 30 minutes probably wasted to hook up and run the machine's program, when a set of plugs, etc. will probably fix the problem.
Thanx again for the kudos. I can still get through the front door, but it's getting a little difficult to squeeze my noggin' through the door on the Jeep.
Beav
