Old 07-07-2004, 09:05 PM
mbtoloczko's Avatar
sans SVX
exhaust port dimensions?
Has anyone measured the exhaust port dimensions at the exhaust manifold mounting surface? Are the ports round, square, oval? Size?
Mychailo
Visit my locker
Old 07-07-2004, 09:12 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I think Todd may have measured the ports on his SVX's engine. I don't believe the shop manuals have any decent pics in them.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-07-2004, 09:17 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
PM SVXfiles. He just did an engine & tranny swap on his son's '96 SVX. The old engine should be sitting around and he might be able to measure the ports and take some pics...
-Chike
2006 Steel Gray WRX TR (sold)
Old 07-07-2004, 10:59 PM
As I remember they were 1.5 ", I'll pull the factory headers, and measure. Tom
Old 07-08-2004, 06:54 PM
1.5" Exhaust port size
Here's the pic I promised. The port is 1-1/2" in diameter. There are more pictures in boxer6's locker. Hope this helps.
BTW, there is also a shot in the locker of the best way to reach the (4) 12mm flywheel to torque converter bolts under the intake manifold after removing the alternator. Tom
Old 07-08-2004, 07:15 PM
Chiketkd's Avatar
Thumbs up
Thanks Tom. Great pic!
Are the exhaust ports slightly oval shaped or a perfect circle?
-Chike
Old 07-08-2004, 08:52 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
this is amazing!!!!! I WAS JUST GOING TO POST THIS Question ...........so the internal dimension of the exhaust manifold is 1.5" ........what about the rest of the SVX's exhaust system?
Also ...anyone know how this 1.5" port size compares to other 6-cylinder engines?
THANKS!
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 07-08-2004, 11:40 PM
JLittell
Mychailo,
What are you up to now?
Old 07-09-2004, 11:30 AM
mbtoloczko's Avatar
sans SVX
Thinking about headers. :-))
Mychailo
Visit my locker
Old 07-09-2004, 11:38 AM
Chiketkd's Avatar
With exhaust ports 1.5" in diameter, would an ideal header size be 1.75" or 2" for maximum flow w/o loss of useful backpressure?
-Chike
Old 07-09-2004, 11:46 AM
mbtoloczko's Avatar
sans SVX
Re: 1.5" Exhaust port size
Hi Tom. Thanks for the pic!
How about intake port dimension?
Mychailo
Visit my locker
Old 07-09-2004, 02:41 PM
wawazat??'s Avatar
Yeah, I'm still around
Not quite so easy Mychailo
The intake ports are strangely shaped.
Pics w/dimensions in my locker.
Todd
Down to none
Old 07-09-2004, 03:05 PM
wawazat??'s Avatar
-Chike
Circular port Chike.
Todd
Down to none
Old 07-09-2004, 03:12 PM
Chiketkd's Avatar
Thanks!
I see what you mean...those intake ports do have an unusual shape to them.
-Chike
Todd
