Old 06-28-2004, 06:45 AM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
ECU and TCU Codes
ok... I did the ECU and TCU Diag's Today
(before i go have my DRIVER Side Ball Joint Replaced
Sence it sounds the same as the passanger side did)
Anyway.. First let me note #1 I've just had my SVX
for about a month now, and right when I got it,
The Speedo would only work if I was
accelerating. Now it doesnt work 99.9% of the time
every once in awhile it will jump, but only for a moment.
ANYWAY.. Now that you know what my speedo is doing...
mabey someone can give me a clue of what I can do
about these Codes:
ECU:
37 - Oxy Left
32 - Oxy Right or Circut
24 - Air Control Valve or Circut
33 - VSS or Circut
TCU
33 - VSS 2
The Oxy left/right im not to worried about at this moment
as I know you seem to always have to replace those.
But how do I look more into the ACV or VSS.
Has anyone had these codes, and what did you do to correct them.. Mabey I can get my Speedo to work for once! LOL
Im just happy that 2,000rps = 60mph
1500 is around 40 I think...
and thats how i've been reading my speed LOL
Any info would be helpful!
Thanks in Advanced
P.S.
I TRIPPLE Checked each code to make sure i wrote it correctly.
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 06-28-2004, 07:32 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
VSS2 is the speed sensor that feeds the speedo and several other things.
If you put your hand down the back of the engine on the passenger side (for LHD cars). There is a small oval plug (B9) below and behind the two fat square ones. If you remove it, it is yellow inside and has three wires. The signal wire is the yellow one with a red stripe.
This thread may help you:
http://www.subaru-svx.net/forum/show...threadid=12278
As you are getting codes from the TCU and ECU, I would hazard a guess that your problem is the sensor, the gear which drives it or the B9 connector.
Old 06-28-2004, 10:59 AM
Sounds like the drive gear for the VSS is broken. I believe several SVX's have become victim to that.
Old 06-28-2004, 04:22 PM
nsm484's Avatar
Teh Geek
What about ECU Code 24 - Air Control Valve or Circut
Any idea what could be causing that one?
Old 07-01-2004, 11:50 AM
Idle Air Controller on throttle body?
