Old 06-28-2004, 06:13 AM
Sonar's Avatar
Sonar Sonar is offline
Unhappy Lost my PS ...
I was driving home on Sunday , came to my fav. curves, and when entering the second one ... NO PS ...!!
I was really struggeling with the steering wheel but managed to get through the curve.
Drove very slowly home and noticed lot's of smoke from under the hood when I stopped.
Checked under the hood and could se lot's of ATF sprayed under the engine.
Have not checked further, but I suspect either a broken highpressure pipe or some sealing in the steering rack.
If it is the steering rack, has anyone here replaced broken rack sealings?
/Sonny (ayatollah of lost controll'ah )
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 06-28-2004, 10:55 AM
I would bet it is either the high pressure line or the return line that went. I have had both go before and the same thing happened. I would think that it would be a hose and not the rack. Hope it is a hose, which is an easy fix.
Old 06-28-2004, 11:53 AM
You will want to clean the oil up and add some fresh stuff to help determine the source of the leak. Many have seen the high pressure line fail. I've also seen the low pressure line come loose and almost fall off.
Old 06-28-2004, 01:49 PM
Mr. Pockets's Avatar
Moderator
The return hose on mine failed. It sucked - the car was really hard to steer.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-29-2004, 07:58 AM
Sonar's Avatar
Today I checked it out, it WAS the return line hose clamp that had come loose!
The hose had popped off and drained all the oil.
I just replaced the clamp with a better one and tightened it up.
Now it works just fine
Thanx for all reply's
/Sonny (Ayatollah of regained controll'ah )
