View Poll Results: Please choose the option that best describes your experience.
1992, no failures 21 23.86%
1992, 1 transmission failures 34 38.64%
1992, 2 or more failures 15 17.05%
1993, no failures 4 4.55%
1993, 1 failure 0 0%
1993, 2 or more failures 0 0%
1994, no failures 11 12.50%
1994, 1 failure 3 3.41%
1994, 2 or more failures 0 0%
Voters: 88. You may not vote on this poll
Old 08-29-2001, 08:22 PM
eddycat2000's Avatar
eddycat2000 eddycat2000 is offline
Dumba$$ Mechanic
Originally posted by svxter
Well, if the transmission works, but the RWD doesn't, it would sound to me like a differential failure, or something of that sort. Perhaps Eddycat will pop in and clarify for us. Otherwise, I'd say it's 2 failures.
It depends on who rebuilt the thing. If Cletus did it, you can't fault the transmission. Just ask Aredub!
Pull my finger!
Old 08-29-2001, 08:23 PM
GT
2 failures by 75000 miles
Old 08-30-2001, 04:17 AM
ehyde111
1992 I bought it at 120000 no faulures to date. It was well maintained. I have 125000 on it now and it is going strong.
Old 08-30-2001, 04:56 AM
92 & 94 Trannys
My 92 LS -Tour had a bad tranny when I purchased it( along with BOTH rear wheel bearings bad) I replaced it with a Legacy Trans, but with the SVX front diff, the front axle bearing failed after about 1500 miles(which is in the original front diff with 148k miles on it) Now it's in the process of a 5-speed swap.
My 94 SVX-L FWD has 86k on it with no failures, I don't think the FWD's have nearly as much failure problem, which is why it's my day to day driver.
Old 08-31-2001, 10:52 AM
kvnobrien
Good Poll...
At this point most of the people have responded with 39-92's voted. Only 2-93's (both without failure) and 8-94's.
Old 08-31-2001, 11:40 AM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
Originally posted by kvnobrien
Good Poll...
I had to dig these up, since there are so many more member on here now, then there were when this was first posted
Kev
kevin.m.sheets@verizon.net
Old 09-14-2001, 06:29 PM
dromano's Avatar
dromano dromano is offline
Originally posted by GT
1992
I hope the second fix is a whole lot better than the first. How many miles out of the 2nd tranny? I have 2 SVX's, tranny went out at 70000 on one. The other is at 76700, no signs of trouble.
David
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 10-17-2002, 11:20 AM
svx_commuter's Avatar
Old 10-17-2002, 04:41 PM
CigarJohnny's Avatar
Originally posted by svx_commuter
In the past 30K miles I have no failures of the front wheel drive but the rear wheel drive isn't working. But it may not have been working when I got the car. Most likely. I know it was replaced under warantee in Brooklyn NYC after about 3k miles and I think it was rebuilt around 43k miles. So is that no failures while I own it or 2 and a half for the life of the car?
I don't know exactly when my tranny was rebuilt but I believe it to be in the past year. As I'm learnig with my '92 @ 72K, the rearend not working is not necessarily the rear diff. The rear drive on mine is slipping bad and chatters like hell when it engages. I took it to my local dealer and the tech went for a test drive in the rain. When we got back to the shop he showed me one that he had been working on and showed me the rear drive clutch that is bolted to the rear of the tranny. It is just a wet clutch pack (just like in most motorcycles) that has the pressure regulated by a little controller inside. My tranny was rebuilt before I bought it but I think it was just that...rebuilt, not replaced. It is very probable that when yours was rebuilt they neglected to replace the clutch pack, or it's pressure controller in the rear of the tranny. That piece just bolts to the back of the tranny and might be a very easy job to replace the cluch. He also said that the rear diffs themselves rarely if ever fail.
Just a thought that might be of some value to you. Hope it is
