Old 06-19-2004, 10:29 AM
n00b on demand's Avatar
Headlight bulb issues
Ok about 2 months ago or so i had replaced the regular yellow halogen headlight bulbs with the "HiLite" clear headlight bulbs. They are pretty good and i can see very well with them but I am having one problem. The drivers side bulb is always going out. Not because of the bulb is bad but the bulb keeps coming loose from the connector. Everynight for the last week at night when i start the car that one bulb never works. I then have to pop the hood..take the bulb out and tightly put it back in. The wattage for the bulb is the correct one for the svx so i dont think it burned the connector out. The other one on the right side works perfectly. That bulb clicks in whereas this one on the drivers side doesnt click in and is always coming loose. I dont know what happened but im not sure what i should do as having to keep popping the hood and press the thing into the connector hard is getting kinda annoying.
Old 06-19-2004, 11:50 AM
Try the other bulb in it and see if it snaps in. If not, you will know that it is the holder that has something wrong and will need to be repaired.
Old 06-19-2004, 12:14 PM
hey Earl, i am pretty sure it is the holder and not the bulb that is the problem. How expensive is it to get the holder repaired? I took the bulb out to look at it and it looked as though something ate away at it because theres a small chunk of that reddish plastic missing. Very small piece of it.
Old 06-19-2004, 12:27 PM
I will check out how much a new one will be.
Old 06-19-2004, 12:44 PM
Thanks alot Earl!......you could just give me one off of your million svx's LOL
Old 06-21-2004, 01:55 PM
check both the bulb and the socket again. I've seen the prongs in the bulb get "pushed in" and cause a poor connection (replace the bulb). I've also seen the socket either melt or become brittle (replace the socket).
I've replaced the socket 2 or 3 times on mine. The last time i put some conductive paste in the holes in the socket before I put the bulb in. I haven't had a problem since. I'm also running 80W bulbs.
