Old 06-18-2004, 01:21 PM
fait_svx's Avatar
fait_svx fait_svx is offline
front rotors
My front rotors are warped. I dont have the cash to replace them right now, but I was wondering, would it be possible to swap the front rotors with the rear?
Old 06-18-2004, 01:28 PM
lee lee is offline
nope, sorry - rear rotors have the mergency brake drum built into them for one thing.
Old 06-18-2004, 01:40 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
You could get the surfaces remachined for pretty cheap. Then slap on some new pads and drive a little slower.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-20-2004, 01:10 AM
svxsubaru1's Avatar
If the rotors arent warped badley, you could switch to some harder pads, some semi mettals or something and those could maybe get rid of the warpage. I did this to a legacy and it worked great.
Old 06-20-2004, 07:17 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
What are the condition of your pads? Get your rotors turned for like $10, and if you're pads are in ok condition, you'll be fine.
If the rotors are slightly wapred and your pads are worn as well, using the semi-metallic pad trick does work. These performance pads are much more abrasive than ordinary organic pads and will eventually 'smoothen' the surface of your rotors again.
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-21-2004, 01:57 PM
You could also try what has worked for some - re-torque your rims to spec then do a couple high speed emergency stops. YMMV.
