Old 06-17-2004, 11:45 AM
n00b on demand's Avatar
so sick of losing power when a/c is on
Ive had my SVX since Nov of 2003 so this is my first summer with this car. Now when i drive other peoples cars i never really notice a loss of power when the a/c is on but in the SVX it is veryyyy noticeable. When i have my a/c on i usually have it in the middle on the second setting with the temp down to 65 degrees. If I am at a red light and i acclerate the car wont rev or and it will move a tiny bit then it will burst out with energy and be fine. When i turn off the a/c this never happens and the car runs normal. Why does the a/c drain so much power?
Old 06-17-2004, 12:07 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
A lot of newer cars use electricity to drive the ac much like electric fans. The SVX uses an older system. It is going to suck power.
You could always just not use the ac
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-17-2004, 12:12 PM
red95svx
Your compressor may be bad
Never happens with my cars. I think the AC drain is very minimal, especially with the variable displacement compressor. Try driving a Loyale or 4 cylinder XT with the AC running if you want to feel some serious AC-related power loss.
Old 06-17-2004, 12:56 PM
dcarrb dcarrb is offline
Not much of an A/C-related power drop in my car, either. (I had a GL wagon with air; like throwing-out a @%&*ing anchor.) But I have noticed an occasional, momentary hesitation from a standing start with the air on, particularly before the engine warms-up. Is that what you mean, soobiesvx93? In my case, it doesn't strike me as a mechanical issue with the compressor.
(Is this the sort of thing the "bead crush" ECU mod is supposed to remedy?)
dcb
Old 06-17-2004, 01:26 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
It's very non-noticeable on my SVX also...on my I4, V6 and H6 engines...H6 has the least noticeable issue on the AC drag....
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 06-17-2004, 02:17 PM
"But I have noticed an occasional, momentary hesitation from a standing start with the air on, particularly before the engine warms-up. Is that what you mean, soobiesvx93? In my case, it doesn't strike me as a mechanical issue with the compressor."
yes that is exactly what i mean. But this is after the engine is warm. If it was cold i could understand but the engine is warm when this happens.
Old 06-18-2004, 08:12 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
I thought the AC compressor was supposed to disengage under full throttle. I don't notice that happening on mine. I remember in my Im,preza that if I was flooring it I'd get a burst of warm air from the vents as the AC turned off. I never notice that happening with the SVX.
I also notice a difference in response when I manually turn off the AC before going into "b4tTl3 m0dE".
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 06-18-2004, 08:27 AM
I still catch myself doing this. It's a holdover habit from the aforementioned GL wagon, in which the practice was essential to allowing the car to accelerate, period.
dcb
Old 06-18-2004, 01:41 PM
I am so sick of driving with "auto" on now. I can have the throttle pressed down and the damn car won't move and then all of a sudden it kicks in. Its 95 degrees here and the inside of my car is like a sauna. I got so mad i was losing power that i decided to drive with "vent" on and i was drenched in sweat when i got home. It was only a 10 minute ride. I mean its absolutley ridiculous.
Old 06-18-2004, 02:09 PM
If it's that bad, I'd have someone check it out.
dcb
Old 06-18-2004, 03:12 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Agreed. I don't notice any major drop in power when accelerating with the A/C on...
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-18-2004, 03:23 PM
IggDawg's Avatar
0h n0es!
same here. it's more of an inconvenience than a handicap.
IggDawg is cool
-IggDawg
Old 06-18-2004, 05:32 PM
Dean
Yeah, I agree with (absolutely no technical knowhow to back it up) getting it checked out.
When having the mechanic ride along with me to reproduce the current engine problem I am experiencing, the first thing he did when I started the car was fire on the AC as cold as it would go and as high as it would go to see if it was related to my problem. I experience no loss of power related to the running of it as far as I/we could tell.
Good luck!
Old 06-18-2004, 07:02 PM
immortal_suby's Avatar
Thread Killah
I get the warm air treatment any time I floor it with the ac on.
I never really had AC before the svx, but I don't feel too much of a drop in power with it on under normal acceleration.
Locker Link
2015 BRZ Limited 6MT
Old 06-19-2004, 07:31 AM
red95svx
I think the "Power" light has to come on in order for the AC to disengage itself.
