Old 06-16-2004, 05:09 PM
SVX ROO SVX ROO is offline
Front Diff Output Shaft - URGENT advice?
While doing a routine ball joint change, the left side diff output shaft dicided it liked the world outside the differential rather than inside. When the ball joint came undone the upright swung out to the side a bit more than I expected. When I tried to put the ball joint in place the half shaft was hanging way out from the diff. My first thought was that the half shaft had been installed without the roll pin. Nope, roll pin was in place but the diff' output shaft had pulled out of the diff and was hanging onto the half shaft by the roll pin.
Anybody have this experience?
I have knocked out the roll pin and separated the half shaft so I have room to work. The shaft came out far enough to see the splined opposite end of the shaft which is only about 6" long.
I looked at the parts cut sheets and it seems this shaft just slips into the splines of the differential. Is there supposed to be something holding it in? I don't see any sign of a seal on that shaft either but I had no leakage. Is there one?
Can I just slide it back in? And than refit the half shaft?
If not, what is the fix??
Ken
'94 Bordeaux
1984 Ferrari 400i (4.8 liter V-12)
'69 Lotus Elan +2 w/Cosworth BDR
'04 Audi allroad 2.7 TT Black
Old 06-16-2004, 05:43 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
How much of a gap was there between the end of the axle and the diff case?
I have never heard of this happening before. I hope you can just slide it back in, that is what I would try.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-17-2004, 06:40 PM
svxpert svxpert is offline
is you SVX at Haddon trannsmission on rt130? i see a white one there when i drive by?
Old 06-17-2004, 08:49 PM
All is well that ewnds well
SVXpert, no it is not at Haddon transimision. I do alomost all my own work.
Now for the end of the story. The front diff output shafts are held in the same way that Honda (sorry for bad language!) half shafts are held in. On the inner end of the 6" long shaft there is a groove about 1/8" from the end of the inner splined shaft. In the grove is a springy open ring, kind of like a circlip but just a springing wire that goes about 70% of the way around. The just "pop" in or out with a little pressure.
Once I got the half shaft out of the way I got the diff shaft in the hole in the spider gear with the splines engaged and one or two taps with a hammer and in it went.
NO HARM DONE, no differnt that changing those half shafts on my former Hondas.
Lesson learned: for me when I change a ball joint again I will tap out the roll pin from the inner CV joint and let it float so it does not pull out the diff shaft.
Ken
'94 Bordeaux
Old 06-17-2004, 08:51 PM
Word to Yo Motha
Good to hear it went back together ok. Sounded a little scary!
Collin
1995 L AWD
Locker
Old 06-20-2004, 12:18 PM
there is a clip suposed to be on the inside end of the small splined shaft. This holds that shaft into the differential carrier. Try to find the old one but if it is not there, get another and replace it when u can.
Old 06-20-2004, 04:29 PM
thanks
Thanks, the clip was still on the inside end of shaft and went together with two taps.
Ken
Ken
'94 Bordeaux
Old 06-20-2004, 06:02 PM
Glad it went backtogether for you, I just saw this, or I would have responded earlier.
Had the exact same thing happen while doing the ball joint on my friends XT6, we ended up just tapping it back in and she's been fine ever since.
Old 06-21-2004, 08:36 PM
good to hear its all kosher
