Old 06-03-2004, 07:07 PM
StooKer StooKer is offline
Limited Slip Differential Additive or...
Hi!
My transfer clutch have been replaced about 8,000km ago and since I have put my summer tire, I have a binding from the rear (I think) when I turn. The problem became worse with time.
I can make the binding go away with a couple of 8 in a parking lot, but when the car is cold the same problem appear again. I think that when the oil get warm/hot, the problem go away.
Should I try the Limited Slip Differential Additive with my 8,000km clutches?
Thanks!
Old 06-04-2004, 12:31 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
yeah you should
don't put too much in...
i have appx a bottle and a half in the car right now (filled it, put a bottle in, drained it, put another bottle in) and it slips.
try half the bottle and see if it goes away.
SV What?
Old 07-19-2004, 09:14 PM
Ryan Ryan is offline
XSVX Owner
Send a message via AIM to Ryan
Nomad,
Sorry to be a thread digger, but was the additive put in the transmission, the front differential, or rear differential?
Thanks,
Ryan - 2002 Subaru Impreza TS Wagon
Old 07-20-2004, 09:15 AM
Transmission
Old 07-21-2004, 12:16 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
unless...
you are talking about the limited slip diff additive. That goes in the back. I just added some to mine because i was having some binding issues lately as well and after about 300 miles it has completely gone away. Its pretty nice stuff. Doesn't take much though. The bottle of additive is 6oz or something, but it did the trick.
~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 07-21-2004, 12:30 PM
XSVX Owner
So we got one for the transmission, and one for the rear diff...
Old 07-21-2004, 02:30 PM
NomadTW's Avatar
if your awd is binding put it in the transmission for the limited slip diff that is the AWD system
the rear diff should have the additive in it already
SV What?
Old 07-21-2004, 03:15 PM
LSD
In the rear diff the limited slip unit is sealed with a silicone fluid. The rear needs no special oils other than the regular gear oil.
Subaru recomends ; API, GL-5
I just used Mobile 1 75/90 synthetic gear oil.
Old 08-24-2004, 04:52 PM
simonton
what exactly is binding?
im having problems that i think might be described this way.
could adding this fluid help me? And if so; how much does it cost, where can i get it, and where do i put it in
