Old 10-31-2001, 08:54 PM
aas0242
Do I need Axle Nut for the Rear Wheel Bearing?
Hi,
Just wanted to ask if its necessary to replace the Axle
Nut when I replace my rear wheel bearing. According
to the Subaru Technical Bulletins, you have to but I
can't seem to find the part # for the rear wheel bearings.
Any help would be appreciated.
Thanks.
-Tony
Old 11-02-2001, 04:05 PM
Mr.Pwrlite's Avatar
Mr.Pwrlite Mr.Pwrlite is offline
Re: Do I need Axle Nut for the Rear Wheel Bearing?
Originally posted by aas0242
Hi,
Thanks.
-Tony
I've used the same axle nut, and put about 30,000 miles on my car since then. I have no problems to this day, I'm sure you can get away with it too. Good luck!
"If it works, tear it apart and find out why!...... "
94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ...
