Old 10-24-2001, 11:22 AM
oneothefewproud
Wayne, are you SURE your rack is leaking
The rack does leak. I have seen it when it was up on the rack. The oil change place told me that also. It is NOT engine oil.
It is also a very light weight oil. The only other leak she had was the value covers. and those were replaced by the former owner right before I took custody of her.
The wife is getting ready to call the donation place and have them pick her up. I hate to see her go like that but the dealer only wanted to give me $2k for her.
By this weekend if noone wishes to give her a good home off she will go.
Thanx
Wayne
Old 10-24-2001, 11:42 AM
fongangus
Ok. If I assume that it's a leaky gasket, how much would that cost? I believe replacing a new gasket would just about less than $100. What about the white smoke only occur as first start and warming up? I used to own a 94 MR2 which also has white smoke coming out. But I ignore it and never have problem on that(at least untill I sold it).
If the coolant leak cause the overheat. Then why it does not overheat all the way to the top? But instaed going up the 3/4 to 1/2??(The overheat especially happen on the local traffic driving)
Old 10-24-2001, 09:24 PM
Invisible avatar
Talking
Or, better yet, offer $900.00, plus say you'll tow the heap away FREE, & then sell the good parts to club members. With the profits you'll be able buy a decent SVX. Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 10-24-2001, 11:14 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Re: Wayne, are you SURE your rack is leaking
The reason I ask is that the rack is $$$, but the hoses around it are much less $$$.
I have a PS leak as well, but there have been more cases of pressure hoses leaking than the rack itself failing. If the rack ain't broken, you've got a car that has very little to repair, and possibly not worth selling to you...
VK
Thanx
Wayne
Old 10-24-2001, 11:20 PM
vkykam's Avatar
If you have exhaust gas going into the coolant system, air/gases would have a higher temperature than the liquid.
When I had a leak in my radiator (at the top of the plastic tank, as many have experienced), the temp gauge would jump around.
In the case of a new head gasket, it won't be $100. Might want to try adding a zero to the end... A lot of labour to tear the engine down to replace the head gasket....
Do a search on the message archive. Someone over at Yahooligans a year back had their head gasket done, and because most of the labour was done already, he tagged on the timing belts and the water pump, and if I remember correctly he ended up paying about $1500.
That car has red flags all over it...
VK
