Old 10-22-2001, 09:33 PM
maestro
lots of smoke and anger
I was driving my SVX this morning on my way to work, when: I noticed a little smoke, no prob as i had seen this once or twice before, i thought. About 8 miles later i looked back to see a very havey trail of white smoke. I thought it was the oil, but it didn't overheat at all. I mad it to work quite disgruntled. Later i checked and the oil is fine, but hteres no coolant. Could the line have just been trickling and then broke? Would coolant on the block smoke? Also gas mileage seems to be terrible in these things, i get maybe 200 miles to a tank (12 gallons?). My father (a mechanic, who has fixed an svx recently [changed both front axles in an hour] ) says to just put oil where the coolant would go and just drive it the 8 miles home. Any iedes on the problem? Thanks.
BTW, now i have to drive an 1980 something 300zx to work
Old 10-22-2001, 10:25 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: lots of smoke and anger
The odor of coolant is VERY distinctive and would not create black smoke. It would create a rather "rancid" steam. Black smoke would be created by a poorly tuned engine or one with a failing combustion chamber. Put oil where the coolant would go? I've never heard of this. Could you have your dad explain?
Randy Johnson
Mike Davis -- at Reading VI
Old 10-23-2001, 08:29 AM
Mr. Pockets's Avatar
Moderator
Gas mileage varies depending on length of trips, consistency of speed, highway vs town driving, outside air temperature, etc. In town in the cold i have gotten as low as 16mpg. On the freeway at a consistent speed and in warm weather I recently got 31.4mpg.
The tank, by the way, holds 18.5 gallons. I would bet that you have the same pessimistic gas gauge that the rest of us do. If I do a lot of town driving, mine will read empty when I've only used 10gal. There is a gas light, though, that I have found to be VERY consistent in my car - it comes on when I have 4 gallons left, every time.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 10-23-2001, 09:17 AM
Zombie
uhhh... pockets?/? What the H3LL are you talking about????
Old 10-23-2001, 10:11 AM
Moderator
I don't have a clue what the answer is to his major problems. I'm actually even confused by his description and his father's suggestions.
But he did mention that his mileage was poor and that he thought his tank was 12gal. So I suggested what factors affect mileage and what mine typically is given those factors.
Okay, so I didn't specifically say, 'I don't have an answer for your loss of coolant or smoke, but concerning your mileage...' Sorry. Jeez.
2005 Outback
END OF LINE
Old 10-23-2001, 12:43 PM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
Re: Re: lots of smoke and anger
He said "would coolant on the BLOCK smoke?" not "would coolant make a BLACK smoke". Get some glasses.
As for putting oil in the coolant resevoir......yes please have him explain....
Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
Old 10-23-2001, 12:54 PM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
You didn't say whether the smoke was coming out of the engine compartment, or the tailpipe. Engine compartment - could maybe be a water pump gasket, blowing back on the exhaust manifold. Tailpipe - ouch, possibly a blown/cracked head/gasket.
Steve
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 10-23-2001, 01:03 PM
Aredubjay's Avatar
Re: Re: Re: lots of smoke and anger
Ryan
OOPS! I'm sorry. It must've been his accent.
Randy Johnson
Old 10-23-2001, 02:40 PM
SVXphile's Avatar
SVXphile SVXphile is offline
Ain't it the truth?
Send a message via Yahoo to SVXphile
Accent
<OOPS! I'm sorry. It must've been his accent.>
No it was his SVX, not his Hyundai; you were right the first time. Don
Cats: Clio, Inky, Sheba, Sparky, Rocky, Cali, Scooter
3 cars: 02 SVT Focus, 2012 Versa...2015 Fiat 500
currently SVX-less
1 wife ("She, who must be obeyed..")
"One advantage of being disorderly is that one is constantly making exciting discoveries"
Old 10-23-2001, 04:39 PM
maestro
sorry, i was agitated when i posted it he didnt say put oil where the coolant goes, he said put water where the coolant goes, untill it gets home (about 8 miles). stupid mistake. Anyway, i started it after puting water in the coolant place, and it runs fine. problem is the transmission barely engages. i put it in drive and it has to be at about 4000 rpm just to inch forward. reverse is like 5k.no smoke though, but i only ran it for a couple of minutes. no engine lights come on either. maybe it isnt coolant at all, but trans fluid?
Old 10-23-2001, 04:52 PM
Moderator
I would absolutely check your transmission fluid level. Hopefully all you need to do is top it off, but it sounds to me like you lost a hose somewhere.
Don't drive it any more until you do this. The transmission is extremely sensitive to heat, and without fluid flowing through it I imagine the heat could build up real fast-like.
Good luck.
2005 Outback
END OF LINE
Old 10-23-2001, 06:48 PM
Aredubjay's Avatar
Phew! That's a relief. I was really getting worried. Hope all works out well for you. I'd definitely check ALL the fluids.
Randy Johnson
Old 10-23-2001, 07:12 PM
Zombie
Dude... mr. Pockets... I feel like and A$$clown. I diddnt even notice the part of his post that mentioned the fule mileage... I was focused on the smoke.... So when I read your reply, I was thinking.... where did tank size and mileage come from???? Sometimes I have been known to accdentally post in thewrong thred. I thought thats what you hade done, when I was just being a moron. Sorry man.... and I thought you were confused.....
Old 10-23-2001, 09:29 PM
Invisible avatar
Wink Re: Accent
Another occidental observation, Don?
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 10-23-2001, 09:43 PM
Invisible avatar
Question
Black smoke - block smoke, oil as coolant, fule mileage, 12 gallon gas tanks.... Jeez, could somebody rewind this thread & start over?
Thanks, Ron.
'01 Miata SE - 79K
