suggested exhaust system
I have some rusting and leaking in the exhaust pipe after the cat convertor where it bolts into the Y pipe. The metal flanges of thepipe are delaminating at the donut gasket and the system is much louder than it should be, it sort of sounds like one of these rice burners nowadays with the big 4" mufflers out the back. What new exhaust would one suggest or can I just replace the section from the manifold to the Y pipe with the cat included?
AND what is best price and place to get it? thanks fellers Tdog |
you live in Cinn ?
cool, my sister lives there, she just got her 1st
94 Laguna Blue Svx. Going to be putting one of our systems on there this summer. For more info, check out our site, maybe we can help thanks Dayle (links below)
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
same exact thing happened to me
You're right, it sounds horrible but I got it fixed. I found a local exhaust place and what we did was to cut out all 3 of the stock subaru cats and replaced the 2 small cats with high flow cats from a mustang and then they welded together a new Y fitting with a piece of flexible pipe.
When it was all said and done not only did it fix my exhaust problem but it increased the flow of my exhaust a lot! My SVX runs ten times better now. The shop was able to do the entire job for $300. I would highly recommend it. If you want more specifics feel free to IM me and I'll tell you more and i think i have some pics that i could show you as well of the job. Let me know. ~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Yeah, what Ray said
Dayle has some good deals on high flow cats and resonators - go with the 2.5" size! -Bill
