power antennas on ebay
Fellers,
Has anyone tried replacing their power antenna with ones I've seen on ebay for $24.95? My antenna stays up about 4". Or is there an easy maintenance i can do to get the antenna to close? Tdog |
there's a procedure you can do to clean the "mast" and apparently it has fantastic results. i'm not sure where to point you, but you could start by looking in the how-to locker and searching for "antenna mast cleaning"
-adam |
Run your mast up and down a few times with a rag that is dampened with WD-40. Works well to clean and lube the mast.
I wouldn't recommend one of those aftermarket units unless I was really that hard up to spend the few extra dollars for an OEM unit. -Mark |
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
Re: power antennas on ebay
Thread Tools | |
Display Modes | |
