Old 12-16-2003, 06:55 PM
listed listed is offline
noisey doors
I don't know if anyone else has had this problem but all 3 of my SVXs make a click-click-click noise when you open the door. I've found the source of the sound to be a worn insulator covering a pin for the door safety (the thing that keeps the door from opening too far). Subaru doesn't show a part number for it, but perhaps some of you have fixes.
thanks,
Old 12-16-2003, 10:23 PM
mbtoloczko's Avatar
sans SVX
The doors on my car make some noise, but its never been a problem as far as function goes.
Mychailo
Visit my locker
Old 12-17-2003, 09:18 AM
Mr. Pockets's Avatar
Moderator
As far as I know, they all do this. There's a slide in the door with 'notches' that hold the door open for you at certain angles. These notches make the clicking sound. I just keep mine well-greased. In the summer they can dry out, get rusty and creak badly.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-17-2003, 10:25 AM
svx_commuter's Avatar
Oh I rebuilt mine. It's called a "door checker". Opposing spring loaded rollers. The roller n spring on the bottom will rust and freeze up and then gets flat spots.
It's real bad when it sounds like firecrackers going off when the door is opened.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
