Old 11-14-2003, 02:44 PM
XQsThaiPoes
What did Subaru use for rust proofing lead? I know the japanese had a problem rust proofing until recently so subaru may have did over kill. I live in socal so I dont need much.
mbtoloczko's Avatar
sans SVX
With a 5-speed conversion, and L model AWD SVX weighs about 3400 lbs. (My 4eat L model with 1/2 tank of gas weighed in at 3490 lbs on the local junkyard scale which is accurate to within 10 lbs.) ok, that's 300 lbs more than a WRX, but 3400 lbs is exactly the weight of the (in)famous Skyline GT-R33 and R34. Yes, you can call the SVX heavy if you want, but if you compare it to other cars that are potentially in the same class, the SVX doesn't score so badly.
I don't think it would be necessary to extend the front of the car to accommodate a turbo. You will have to be inventive in your placement of components though. Try the ForcedAirTech website to see where they stuffed their turbo. The intercooler can be placed in the wheelwell between the body of the car and the plastic splash shield.
Mychailo
Visit my locker
Old 11-14-2003, 02:46 PM
CigarJohnny's Avatar
Originally posted by Mr. Pockets
I've also thought about a rear-engined EJ22 turbo Justy with AWD. That'd be pretty slick - basically a turbo Legacy drivetrain, mounted backwards in the car.
That would leave you a car that could only do about 30 going forwards and maybe 140 in reverse. Steering would be a bit twitchy, especially at speeds like that.
Old 11-14-2003, 02:49 PM
Mr. Pockets's Avatar
Moderator
You need to watch more Junkyard Wars - I'd flip the differentials upside-down.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-14-2003, 02:55 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
That is one good episode. Perhaps those guys might have won if the tranny did not fail.
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 11-14-2003, 02:56 PM
Chicane Chicane is offline
Anti-BS Vigilante
Supras weigh 3515 lbs.
SVXs weigh 3525lbs.
I really don't think they're that heavy... I mean, compared to a metro, yeah, but not compared to most GTs.
- Rob
Old 11-14-2003, 03:49 PM
XQsThaiPoes
Its in the same class as an Skyline? The problem is the extra weight of a turbo or super system. So about 3500lbs?
I am beginning to think it would be a shame to strip mint SVX. How much does a beater with trans trouble, and “a lion in the back seat” go for?
My goal is something I can drive around town, but has a high top speed so I can find a salt flat on the weekend and run WOT until I'm out of gas . Since the car is so rare maybe put an unofficial "California's fastest street legal SVXes" title under my belt.
Old 11-14-2003, 04:02 PM
Zinc.
Old 11-14-2003, 05:43 PM
mbtoloczko's Avatar
sans SVX
If your goal is just to go WFO, buy a 1992-93 LS-L and just do a few mods. In stock form, they can and will go 160 mph. If you plan on doing it often, then you should do a few mods like add an ATF cooler and update the suspension.
Mychailo
Visit my locker
Old 11-14-2003, 10:36 PM
Anti-BS Vigilante
Uh... how? Mine pulls REALLY slow at above 120.... but I haven't really found a long straight abandond road to test it out...
- Rob
Old 11-15-2003, 01:11 AM
mbtoloczko's Avatar
sans SVX
As long as the TC will lock up, I've had no problem going 140 mph. Last time I tried, I did it going up a mild incline. When the TC won't lock (ATF too cold), I can't get much above 125 mph.
Mychailo
Visit my locker
Old 11-15-2003, 01:53 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
back when my svx ran it pulled hard over 120... my friend w/ a mustang remarked about how hard it pulled over 120
i must reiterate chicane... ur svx is slower than the rest.. get that looked at
SV What?
Old 11-15-2003, 04:30 AM
so if the torque converter doesnt lock, you cant surpass 120 or so? can this be the reason i am topping out at 125 even after testing it can do over 140?
Old 11-15-2003, 09:08 AM
Anti-BS Vigilante
Originally posted by NomadTW i must reiterate chicane... ur svx is slower than the rest.. get that looked at [/B]
My car is fine. The engine is fine, the transmission is fine. The windshield and 1/4 panel, thats another story, but mechanically, its tip top. Last time I posted my spring to 125, a few of you said it was so slow, but I also got QUITE A FEW pms telling me not to listen to the trolls, because their car is the same way.
- Rob
