Old 11-11-2003, 11:28 PM
mbtoloczko's Avatar
sans SVX
Originally posted by Chicane
(first find the mep of the 3.3 liter H6)
230 / (3.3*6.5)= 10.7
- Rob
I wonder if its more appropriate to calculate the MEP using the rpm at peak HP (5500 rpm). In that case the MEP would be 12.7. You still get the same answer for your HP estimate at 3.8 liters though.
Mychailo
Visit my locker
Old 11-12-2003, 02:34 PM
drivemusicnow's Avatar
Poor College Racer
what sort of increase would you expect from lightened heads with a *Higher* compression ration... if any other internals would have to be changed... just wondering what the effects of a 11:1 or 12:1 compression ration would be.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
