View Poll Results: Wheel Weights: outside rim vs taped inside
I have weights on the outside rim 8 32.00%
I have the weights taped inside the rim 13 52.00%
I don't fall under either of those two choices! 4 16.00%
Voters: 25. You may not vote on this poll
Old 11-06-2003, 08:28 AM
Shadowyng's Avatar
Shadowyng Shadowyng is offline
Directionally Challenged
Send a message via AIM to Shadowyng
Wheel weights: on rim or taped inside
Just had my rims straightened and painted during the summer. When I had the balancing done I insisted that the weight be tapped on the inside instead of having them muck up the outside of the rim. Plus I think it looks better with out those ugly weights on the outside. Any noise out there on the differences???
Old 11-06-2003, 09:07 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Mine aren't "taped." They're regular balance weights, but, installed on the inside. Gives the wheel a cleaner look, IMHO.
Randy Johnson
Mike Davis -- at Reading VI
Old 11-06-2003, 11:10 AM
svx_commuter's Avatar
Taped weights for the street for looks and clamp on to race with so the glue doesn't melt.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 11-06-2003, 11:46 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
How can you have them only on the inside? I used to work in a shop and I have never heard of this. The machines tell you where to put the weights. Is this a different kind of weight?
I have the regular weights. And I have two 'perfectly balanced' wheels with no weights.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 11-06-2003, 11:53 AM
Shadowyng's Avatar
they still put the weights on both sides of the rims but the outside weigths are thin strips with adhesive that are aplied just on the closest edge just inside the rim.
Old 11-06-2003, 12:13 PM
Aredubjay's Avatar
I dunno. I used to work at a shop too and we ALWAYS put the weights on the outside. That was YEARS ago (we used a good ol' fashioned bubble balance). I guess today's computer spin- balance machines can balance either way. I'll have to ask, next time I'm in for a rotation.
Randy Johnson
Old 11-06-2003, 12:18 PM
mbtoloczko's Avatar
sans SVX
Re: Wheel weights: on rim or taped inside
Make sure that they don't put weights just on the backside of the rim. There should be weights tapped towards the front of the rim (typically just behind the spokes) to take care of any out-of-plane balance.
Mychailo
Visit my locker
Old 11-06-2003, 02:26 PM
drivemusicnow's Avatar
Poor College Racer
There are the tap ones on the outside, but on wheels like mine, you can't use the outside weight, it HAS to be put on from the back or brake side of the wheel, depends on the lip, and whether you dislike the look of them. these are not taped one, but rather very similar to the tap on from the outside, but it hooks on to something on the inside of the wheel.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-06-2003, 03:03 PM
mbtoloczko's Avatar
sans SVX
The modern spin balance machines have two modes, one where the weights go on the front lip and back lop to handle out-of-plane balance, and another mode where the weights go only on the back lip. This latter setup is for wheels without a front lip. Lots of the flashy alloys do not have a front lip. The more advanced spin balance machines can deal with no front lip by telling you to put weights just behind the spokes towards the front of the rim to handle out-of-plane balance.
Mychailo
Visit my locker
Old 11-06-2003, 03:39 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
For me, the question is "Where should I have wheel weights?"
Old 11-06-2003, 04:28 PM
marlettpat marlettpat is offline
THE MEMBER
Send a message via AIM to marlettpat Send a message via Yahoo to marlettpat
my dad works as a tire/wheel installer salesman and he does em on the outside mostly. he will put them on the inside if it is an aftermarket rim of anykind because it will scrath the rim easily if it is where the rim and sidewall meet.
Pat
Would love an SVX of my own...
Old 11-06-2003, 09:23 PM
DWayne2910
Besides looking clunky and possibly marring the rims, clip-on weights can also cause corrosion (pitting).
I always have my balancing done with tape weights.
Old 11-10-2003, 09:40 AM
96svxer
I'm an inni, not an outi.
Old 11-10-2003, 12:46 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
I'm a nonni
(In perfect harmony with my aluminium)
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 11-10-2003, 01:02 PM
mikecg's Avatar
mikecg mikecg is offline
I just got custom rims. This is the first time I've had them taped on the inside. I'm not fond of it. The rims have reletivly small spokes and theres a large group of wieght right in between two of them were you can see them plain as day. I dont know how confedent I am that they'll stay. Especally if I lose my mind and try a high speed jont up the parkway.
