Old 09-22-2003, 05:19 PM
SVXGIRL182 SVXGIRL182 is offline
Changing pads and rotors.
My rotors from Motorsport Wharehouse arrived at my house today. On Thursday we will be putting them on along with new pads. My only question is this. Is there anything I should know about changing these pads. I've done it on numerous cars, but when it comes to these things, the SVX always seems different. If you guys know anything that will help me do the job easier that'd be great.
Thanks
See my car @ http://www.nicez26.homestead.com/NicolesPage.html
Old 09-22-2003, 06:29 PM
Subafreak's Avatar
Superbeast
I would say the SVX is one of the eaisiest cars to change brake pads on, if you have expirienct with other cars this one should be a snap. Good luck.
Old 09-23-2003, 12:42 AM
The Molinator
ROTORS and PADS!
Wondering if you got the cross-drilled rotors ($200 each) for the front like I did. Mine came with two drill holes missing! I ended up drilling the two missing holes myself. They are working OK - I'm getting them turned now (1 1/2 years later, about 30 K miles). [It turned out for me that the new fronts made no difference>> IT WAS THE REARS that were warped!]
Pads are routine, nothing tricky. Have FUN!
Jim
Old 09-23-2003, 09:26 AM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
Go to www.ryanmacdonald.com then click "Sunfire/SVX" on the left hand side, then scroll down to "SVX howto's". On the next page there will be a selection for a brake how to. Very descriptive and should help you out alot!
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 09-23-2003, 12:49 PM
I ordered the set of 4 Brembo I think slotted zinc coated rotors. They were less than $400 for the set. Really good deal. I'll check that out. Thanks alot.
