PCV valve hose
another question what kinda hose is going from PCV valve to air intake?
should it be oil compatible pressure hose or just oil compatible will do? and the SVX PCV valve, is it same as any other car valve? so i can get it in parts shop and not subaru dealer... cheers |
The PVC hose holds no real pressure, so regular oil compatible hose would work except the hose is in a pre molded shape that I don't think you could ever get a regular piece of hose to bend in without kinking. The SVX PVC valve is the same one used in all the Legacys and broply the Imprezzas to, so you should be able to get one at a local parts but you will have to go to Subaru for the PVC hose.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
PVC Valve
PCV Valve - 11810AA000 - (List - 9.00) SVXNet-7.20
