Old 07-06-2003, 09:36 PM
svxjoe's Avatar
svxjoe svxjoe is offline
Only SVX @ UCF (Cool!)
Send a message via AIM to svxjoe
@ 60mph-65mph (power-ranges)
Originally posted by svxeno
Here I am yesterday driving the toll road home from work going about 60 -65 MPH. I come upon a merge point, traffice is fairly heavy behind and next to me but I left my usual space in front. The driver merging isn't speeding up or slowing down, just pacing me <idiot>. Now I need to speed up and SOON. I press the accelorator down about 3/4+ and it starts to speed up then SNAP! power mode kicks in and I take off like lightning. I think it even surprised the SVX!
I adjusted my TPS some time ago so it takes less pedal to downshift and/or go into power mode. What I don't understand is why is it sometimes like a rocket and others it just accelerates nicely in power mode? I've NEVER had it perform like it did yesterday.
Any ideas?
Randy ii
Well, I've played with this Power Mode alot when driving. It seems that in the in the 55-60 mph range the accelerator is very sensitive to go into Power Mode, and that it doesn't even take the pedal being pressed to the floor. 60-65 mph seems to be that perfect power range that when the pedal is pressed the SVX seems to "take-off".
Another one is.... try taking your foot off the Accelerator pedal and slowing to the 15-20mph range (and while still rolling) STOMP on the gas to the floor.... this will also give you that "take-off" feeling....but only til about 40mph....then the "take-off" feeling dies off again.
So my idea is that there are certain ranges of the Power Mode that perform better, and produce more thrust. These power ranges make the SVX seem like it's incredibly fast, and if you time the 15-20mph range just right you'll find yourself peeling tires out of turns, and thats exciting!
-SVXJoe
Old 07-07-2003, 01:03 PM
Paxton71
boost mode
Yeah, I too have felt this on my '92. Most times we just accelerate normally, in "power" mode but sometimes...It REALLY does take off. And the faint odor of way rich exhuast accompanies it.
37 HP, no. But sometimes...WOW.
I think it has something to do with the GF's hand on my knee.
*shrugs*
Old 07-07-2003, 05:46 PM
Subafreak's Avatar
Superbeast
Ya, right, on your knee, sure.
Old 07-07-2003, 06:01 PM
double pump the accelerator for a nice take-off. when you do that, it seems like the ECU says "OH! you wanna go fast, huh?!?!"
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 07-07-2003, 06:05 PM
mbtoloczko's Avatar
sans SVX
Re: @ 60mph-65mph (power-ranges)
-SVXJoe
My suspicion is that it has nothing to do with engine performance and everything to do with AT behavior. I think that when stomping the gas pedal to get into power mode, besides letting the motor rev all the way to redline, the AT allows less slip in the TC. The reduced slip means that a greater percentage of power makes it to the wheels and is not turned into heat in the TC. The fact that it really stuffs you in the seat when you stomp the pedal at certain speeds is probably because you are hitting the meat of the powerband (eg about 4500 rpm) when the car goes into power mode.
Mychailo
Visit my locker
Old 07-07-2003, 08:13 PM
svxjoe's Avatar
Re: Re: @ 60mph-65mph (power-ranges)
This is exactly what I meant.
