Old 06-24-2003, 12:53 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
Question Price Question
I pulled my CE codes today and found that i have a right O2 sensor out and my water temp. sensor is getting bad readings. anyone have an idea of how much this will cost to take care of?
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 06-24-2003, 01:17 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
the coolant temp sensor went bad on mine, it was like 9 bux and took about 30 seconds to change it once i found the right socket to use... although i needed a deep well socket because of the plug on the end of the sensor
i ended up using a spark plug socket and removed the rubber ring in it and it worked fine
the O2 sensor is a bit more involved, and more expensive, i recomend going to carquest for the replacement part if you're doing it yoruself it'll only be like 60 bux... you'll have to get under the car and unscrew the old one unplug it screw in the new one and plug it in... it's not an involved process but wheel ramps or a lift would surely help
if you plan to have someone else, ie a dealership or something fix the o2 sensor expect to pay 150 bux or so for the sensor plus at least an hr in labor
i would sereously not recomend paying them to fix the coolant temp sensor it's just too easy to fix, easier than changing oil...
no need to pay them 80 bux to fix something that takes 30 sec to unscrew and put a new one in, it's REALLY REALLY easy
on a scale of 1-5 of difficulty 5 being most difficult i would rate it a 0 in difficulty
SV What?
Old 06-24-2003, 01:19 PM
NomadTW's Avatar
oh on another note, the coolant temp sensor, will probably cause your car to not start when it completely goes...
SV What?
Old 06-24-2003, 08:06 PM
Subafreak's Avatar
Superbeast
It's also possible that the bad CTS is setting a code for a bad O2. If the CTS is making the car run too rich or too lean it could cause a false O2 code be cause the computer can't straiten it out it blames the O2. Try just doing the CTS first and clear the codes to see if the O2 code comes back.
Old 06-24-2003, 10:37 PM
jsvxstyle jsvxstyle is offline
MINEZ BETTER
true
you learned that on toyota's
i know it did on the o2 sensor code on a toyota
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon
Old 06-25-2003, 11:32 AM
Kerven Subaru
Here are the prices I have for the sensors you may need.
The O2 sensor (22690AA180) $82.77
Your car has two of these, left and right. The code you are pulling should indicate which is bad, but I would recommend that you replace them in pairs.
The CT Sensor (22630AA041) $14.68
Old 06-25-2003, 12:47 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Based on those two listings, you appear to be 31% off of list prices. That makes you the lowest by quite a lot.
I wish I would have known that two weeks ago before I ordered the eighty-nine parts that I did. Next time I'll buy from you. That's the cost I pay for not reading every post
What's your shipping/handling rate?
Could I have it sent freight collect on my UPS or FedEx account and just pay the parts prices, or is there a mandatory handling charge?
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 06-25-2003, 12:58 PM
petesvx2's Avatar
thanks guys for the responses, i had an idea that maybe when they replaced my O2 sensor last time, maybe two months ago, maybe the code was never reset and the ECU is still thinking its bad, or it could just be the other side. how much to have someone else replace the coolant sensor? where is it located?
Kenwood KDC-MPV619
Wedgie Cupholder
Old 06-25-2003, 01:22 PM
Kerven Subaru
Doug
Doug-
We charge 'roughly' actual shipping charges via UPS Ground. I say roughly because sometimes our estimates on shipping are a little off from what it actually is. There is no handling fee. I am not sure about sending parts freight collect. I will look into this issue.
Mike
Kerven Subaru Parts
Old 06-25-2003, 02:27 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Does that come with a raw fury dog and fishnets?
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
