Old 02-10-2003, 02:15 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Re: Re: OEM Brake Pads. Where?
Originally posted by mbtoloczko
What was it in the message archive that convinced you that OEM pads were the way to go?
I remember a comment on the forum a little while ago stating that when the SVX was introduced, the reviewers lauded the brakes for their stopping ability. Those tests were presumably done with OEM pads, so . . . perhaps the OEM pads aren't so bad.
Or maybe they were really good back then but, like so many other things in life, have gradually declined in quality over the years.
My only regret is that I can't buy genuine Mopar brake pads for my SVX because, as we all know, Mopar rules!!!!
< hey! what happened to my dang windshield wipers??!!??! >
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 02-11-2003, 09:29 PM
Earthworm's Avatar
Meow!
Does anyone have a good photo of what the brake shims look like?
Old 02-11-2003, 10:45 PM
mbtoloczko's Avatar
sans SVX
A reasonable sketch is here:
Front shims are parts 26233B (2 needed per wheel) and 26233C (1 needed per wheel). 26233B are black rubber coated. 26233C is shiny metal.
http://www.subaruparts.com/diag/?mod...category=262-1
Rear shims are parts 26633 (2 needed per wheel) and 26633A (1 needed per wheel). 26633 are black rubber coated. 26633A is shiny metal.
http://www.subaruparts.com/diag/?mod...category=263-1
Mychailo
Visit my locker
Old 02-12-2003, 06:36 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
Just ordered my pads.
http://brakewarehouse.com
$95 shipped for:
Front Axxis Ultimates (better than the Axxis Metalmasters)
Rear Axxis Metalmasters
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 02-12-2003, 12:13 PM
mbtoloczko's Avatar
sans SVX
BTW, if anyone wants to compare the characteristics of the various Axxis pads, have a look here:
http://www.axxisbrakes.com/technical.htm
Mychailo
Visit my locker
Old 02-26-2003, 04:22 PM
rogueBeaste rogueBeaste is offline
[QUOTE]Originally posted by mbtoloczko
[B]
What was it in the message archive that convinced you that OEM pads were the way to go? About 2 months ago, I replaced my OEM brake pads with Axxis Deluxe Plus organic pads (as well as having the rotors turned), and I was astounded at the improvement in braking performance.
I've done the same; mine are organic pads and seem to be much better than the OEM, especially if you like progressive feel to the pedal.
FWIW,
bill
