Old 02-17-2003, 09:00 AM
Speedklix's Avatar
Locker Link Solution
Need vacuum help
There is a vacuum hose that runs from the top of the throttle body to ??? I'm not sure if it was supposed to be there, but it ran down though the manifold where the pcv valve is. It broke cause it was so brittle (sub-zero here), but when I fished out the other end there was a screw in it (as a plug)! Where is it suppose to lead to? I can put a pic up later if thats what it takes.
Thanks,
Mike
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-17-2003, 06:41 PM
Speedklix's Avatar
nevermind, I found it. it was the purge control solinoid. And where it was suppose to attach was another plug! I hope this wasn't done for some strange reason, and the person that did it just didn't see the connection between the two.
-Mike
[SIGPIC][/SIGPIC]
